I need a new self-test diary, how do I order one>
BOSS SF-4600C still works but top & bottom have come apart. No way to back-up.
Source: http://imslsoft.com/faq.htm#faq1
What do I need to communicate between my Casio digital diary and my PC?
Most Casio Digital Diary models have a small 2.5mm serial port built into the side of the unit. It can be used to communicate between two Casio Digital Diary units, or with another serial device such as a PC (or a serial printer on some older models).
To connect between two compatible Digital Diary units, you need only a 3-lead crossover cable with a 2.5mm plug on each end, such as Casio's SB-60 or SB-62 cable. You can buy these cables from a Casio accessory supplier such as Windows Link.
To connect to a standard 9 or 25-pin RS232 PC serial port, you need a special Casio-specific adapter cable (more information below). The Casio diary uses its own unique communications protocol, and requires a Casio diary backup program on the PC. You can build your own cable or buy one by mail order, and use it with shareware software such as XLink/Win, or you can buy a kit complete with cable and software such as those sold by Casio or Windows Link
For more information on serial cables, see Cables. For more information on software and kits see What communications packages are available for the Casio digital diary?
Oct 18, 2008 | Casio Boss Business Organizer
Blood sugar testing diary
Check your local drugstores they may carry the..or go in on theAMERICAN DIABETIC ASSN web site they can help..good luck..
Apr 22, 2014 | Beckton Dickinson Health & Beauty
How do you change your password on a youniverse keep safe diary
You push the reset button on back under the batteries pannel if you dont remember the password. Then after that (or if u just want to change your password, open the dairy, push the change password button, while diary is still open type in your new desired password then simply, press the change password button again and shut the diary. You are now all set
Jan 29, 2011 | Toys
Where can I download a User Manual for a Casio BOSS SF 4600?
Casio Japan has published some of their SF Digital Diary manuals online at http://world.casio.com/sf/download/en/manual/ .
You can also try the Casio support web sites for other countries, as they sometimes keep manuals around that Casio Japan has deleted. You may have to look around the site a little, as sometimes the technical support pages are not linked to the public pages. For example see: http://www.casionz.co.nz/Site/Pronto/Files/user_manuals/sf4000%20USER%20MANUAl.pdf (substituting some other model numbers like SF4600B also works with this site).
http://www.usersmanualguide.com/casio/pocket_viewers has manuals posted for many old and new Casio Digital Diary models (thanks to Matt W. Ammons for the link), but one of the sites they link to at Casio has gone offline, so some of the links don't work.
IMSL Software has created downloadable generic user manual for all Casio diary models. This brief manual attempts to cover all models and major features in one document, so it doesn't go into a lot of step-by-step detail, but it does cover all the basics for all common models. The manual is a Word document in Zip-compressed format, so you must have an unzip utility like WinZip installed to open it.
To order a new original manual from Casio in the USA or Canada for any Digital Diary model, try the contact numbers listed immediately above under Casio Contacts.
(the web site structure changes too frequently to link directly to individual pages - select Support for technical support, or select Casio World to find the rep nearest to you)
Casio actively removes information on any products that they are not currently shipping, so don't expect to find much support for Digital Diaries on their web site. You might find more on some of the International sites like Casio UK.
Casio USA Technical Support
800-962-2746
or
800-661-2274 Casio USA Customer Service
570 Mt. Pleasant Ave
P.O. Box 7000, Dover, NJ 07801
973-442-5707
Closest Service Center
800-634-1895Instruction Manuals
973-252-7570
800-428-7267 (Howard Sam -may be outdated)
Parts
800-272-0272, 800-633-0633, 800-421-5080, 800-418-2345
Batteries
800-431-1332, 800-345-0537, 800-942-1944, 800-272-0272
Casio Canada Ltd
100 Commerce Valley Drive East
Thornhill, Ontario L3T 7R1
Tel: (905) 882-0700
Fax: (905) 882-6608
Support 800-370-9083 ext. 242
Manuals: 800-661-2274 ext. 235
Jan 02, 2011 | Casio Boss Business Organizer
How do i restart the "Diary Girl" game?
Enter the wrong answer to the password questions until it takes you to a screen that says to consult the manual. Then press the L and R & Select buttons simultaneously. You can then enter a new password. You will also have to go in and edit out any previous entries made. You can also setup your profile again by going to the settings area.
hope this helps and please vote for me
Dec 07, 2010 | Konami Diary Girl for DS
Harvest moon ds isnt working when i try to load both diaries but they both freeze im not sure if year and dat matters but its winter 9, year 2 need help please!!
Ah...my favourite game.
Try to restart the game on one of the diaries.Turn it off instead of saving.Reload the diary that is the higher level. If this doesn't help then try to play on the new game diary until you can save. Save the game then try to reload the higher level game. This should work. If not you may be having problems with the DS itself. I've heard alot of problems recently about the internal clock.
I'm thinking that you've just hit a glitch in the game and that this should work though.
Good luck.
Aug 16, 2009 | Video Game Consoles & Games
Looking for master password for my secret diary ds game
The Master Password to the game is oxygen. After you type that in you need to pick a new password!!!!!
Mar 28, 2009 | Nintendo DS Lite
Hello Kitty Electronic Password Diary
Take the battery cover off. In the top left corner is a teeny-tiny hole. Depress it with the end of a paper clip that has been unfolded. This will reset the diary so you can enter a new password.
Dec 30, 2008 | Blue Box Hello Kitty Electronic Password...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
