Question about Tablets & eReaders
My tablet settings will grow in size to the point that I can not see but a small % of what it is saying and it is hard to get back to normal size. It happens a lot.
Get a full screen on face book please
Suggest to first try logging into Facebook using the browser on your tablet instead of the facebook app. If that display is normal in size ... it's probably easiest to
(1) uninstall the Facebook App (Control/Settings/Apps);
(2) reboot the Tablet;
(3) Restart the Tablet and Go to the Google Playstore ...reinstall the Facebook app.
Mar 08, 2015 | Samsung Galaxy Tab 2
Where does a sim card go in a zeepad 9rk
Normally on the side. There will be a cover so it will be hard to see. Just lift the cover
Jan 25, 2015 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
How do I reboot after powering up tablet?
There is usually a reset switch to do a hard reboot somewhere on the tablet, perhaps a small hole on the back through which the end of a paper clip or pen point can be poked. Check your user manual for location. Alternate, do a shutdown using the power switch and startup fresh. Some tablets you can hold power switch 'on' for several seconds and get a menu for shutdown or restart. Again, check the manual.
Oct 31, 2014 | Tablets & eReaders
Why won't my 7DRK go on to the internet/?
Has the device previously been able to access the internet....or is this is new device that you are trying to connect with? You may need to setup the tablet to access your wireless router. Most are password protected and this must be set up before network and internet access are permitted.
Jul 31, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Sometimes the display of my ipad 4th gen. Zoom in, how do i bring it back to normal size?
Sounds like you have the Accessibility settings enabled... check the Settings icon
Mar 23, 2014 | Apple iPad 4th generation
I can't get into my emails
Be sure that you go into settings and see if the password is there. Usually it can grow feet and walk away and then you will be asked to enter it again. See if that helps.
Jan 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Tablet freezes on boot up at android screen
Do a factory reset. Turn the tablet off. Wait 10 seconds or so. Hold down volume down button while pressing the on button. Keep holding down both buttons until you see an android icon. It may be laying on its back with a red exclamation mark over it, like I saw. Once you see the icon, let go of the buttons and press the "back" or return button. This should bring up a list of options. You can scoll through the list by using the up or down volume buttons. I picked the option to delete all user data, which basically will set the tablet back to factory settings, like when you first got the tablet. Once that is complete, reboot the tablet.
Mar 24, 2013 | Iview 760TPC Android Tablet, ARM Cortex-A8...
How do i download music from my laptop to tablrt
I highly recommend installing DoubleTwist after you follow the instructions below. The DoubleTwist program lets you do media sync to any android device, it's slick and simple.
Connect your tablet to the computer using the included USB cable (small end to tablet, normal sized USB end to PC)
A USB icon will appear in your notifications bar at the top of your tablet's screen, drag the bar down to open the notification.
From here you'll choose to mount the storage drive (either internal or an external card if you have an SD card installed).
Once that's done your tablet should appear as a "Mass Storage Drive" or another hard drive on your PC. From here you can drag and drop files into it, or use DoubleTwist to do that automatically.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Dell min laptop ,Error message says Delete restoration point and proceed,What does it mean
The restoration point refers to it being placed in hibernation. The computer loads all the active ram into a portion of the hard disk and then when you boot your computer it loads is back, however if this portion on the hard drive is corrupted you may not be able to boot up and it will give you this message, As your computer is booting you can hit space bar and it will let you delete and start normally, If you press F8 right before the point windows starts booting you will have other options and can start windows normally through there.
May 03, 2010 | Dell Tablets & eReaders
Tablets & eReaders Logo
53 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
