The comfort tray is very small can only get a small amount of comfort in compared to my last samurai washing machine
  • 1294 Answers
SOURCE: WASHING MACHINE will only work if a very smalll amount of washing in
Check out your belt. It should "give" about half an inch, or it would be too loose or tight. Change if loose. Also check out your outlet filter. Refer to manual.
Pl. rate if helped ..............
Posted on Dec 31, 2007
  • 1028 Answers
SOURCE: Washing a down comforter.
yes but use a gentle cycle also ck for open seams or tears in comforter first if torn may cause stuffing to come out and plug pump
Posted on May 19, 2008
  • 5911 Answers
SOURCE: washing machine clogged with dirt
You probably have sediment clogged in the inlet hoses and/or screens in the water inlet valve of the washer. First, turn off your water taps in the back of the washer. Disconnect the hoses one at a time and insert them in the wash tub. Turn the water taps back on to see if you are getting water through the lines. If not, you will need to remove the hoses and flush them out. If the hoses appear fine, inspect the sediment screens on your water inlet valve (this is where the hoses connect to). You can use cotton swabs to remove most sediment. If you cannot get the screens to clear and/or if sediment has gotten inside the water inlet valve, you will probably have to replace it. Try flushing the lines and cleaning the sediment screens, first, though. I hope this helps you.
Posted on Aug 04, 2008
  • 8 Answers
SOURCE: My magic delux is leaking water.
Possibly coffee grind to fine (adjust to a coarser grind) or blocked filters in central unit, try using a brewer de-tannin powder to clean. If neither of these seem to be the problem check the o ring that seals the central unit to the machine which may be leaking - if you remove the central unit you will see a cutout in the side panel of the machine inside you should see a vee shaped nozzle with an orange o-ring that may be the problem.
Posted on Jan 09, 2009
SOURCE: Water stays in detergent/bleach tray
There is a small piece that goes over the tray but it serves no purpose accept to tell you where the detergent, bleach & fabric softeners go..
Posted on Jun 21, 2009
Detergent not completely dissolving and small amount of water on the floor
Check detergent is properly inserted. if the tray is not fully in detergent will not dissolve and also water will spill. OR the water pipe may have pushed back.
Dec 08, 2016 | AEG Washing Machines
Novotronic Premier 520. Why doesn't Comfort Fabric discharge automatically?
Probably dirty tray if never serviced there is a blockage in the tray you can take the tray out and clean it if is clean then motherboard problems or valve fault hope this helps
Mar 06, 2016 | Miele Washing Machines
Hotpoint WMF720 Aquarius+
Hotpoint WMF720 Aquarius washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 28, 2012 | Hotpoint Washing Machines
Maytag neptune frontloading washer overflow
If you cannot clear the line, you will need to replace it. Here is the line to order.
Nov 22, 2012 | Washing Machines
The last couple of washes our conditioner tray the middle section isn't draining anymore
take drawer out give it a big clean ...all the holes ect .. clean inside machine part too.. job done :
Feb 27, 2011 | Washing Machines
1. After brewing a cup of coffee, when the grinds are emptying, a stream of coffee and grinds drains into the Drip Tray from the valve(?) in the rear right of the Drip Tray. We have gone into program mode...
Excess water into the drip tray is an indication that you don't have enough coffee going into the brew unit. There is a lever on the top of the door that has a + on one side and a - to the front. Push the lever back to the full plus, then pull it forward 1 click. Try that.
Water into the drip tray is normal in small amounts. This is the release of pressure after brewing, like the 3 way valve on commercial machines
Sep 29, 2009 | Saeco Magic Comfort Plus Espresso Machine
Water below brew unit in excess coffee tray. Over flows to counter top. Can I fix this and what will I need. Thanks, Jim
Remove the brew unit there is a small chamber under the white plastic valve, clean chamber of coffee grounds and water, there is also a small discharge to drain tray make sure it is not blocked.
Aug 22, 2009 | Saeco Magic Comfort Plus Espresso Machine
Won't spin on last cycle
The pump is supposedly self cleaning.
There's a 'pre-chamber' behind a panel at the bottom on the front. The top of the panel should tilt forward & up. Turn the 'pre-chamber' anti clockwise, after putting a shallow tray under it to catch the small amount of water that may be there.
I think I have a pdf manual (found on web somewhere) on another computer, I'll have a look & send it to you if you can give me an email address.
Feb 24, 2009 | Indesit W 123 Front Load Washer
Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
