Question about In Office Equipment & Supplies
11cm in inches - In Office Equipment & Supplies
  • In Master
  • 5,309 Answers
4 and a quarter inches
Posted on May 12, 2017
What is metric conversion for 4.5 inches
Funnily enough, an inch is actually defined as 2.54cm exactly.
Setting up ratios 1 inch is to 2.54cm as 4.5 inches is to x cm. Cross-multiply to get your answer.
You should then check if your answer makes sense. 2.54 x 4.5 can be broken down to roughly 2.5 x 4.5. Now split the 2.5 into (2+ 0.5) x 4.5 and I get roughtly 9 + 2 or 11. So you answer should be somewhere around 11cm.
Good luck.
Paul
Nov 18, 2015 | Office Equipment & Supplies
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
I want to secure 6 Compaq CQ2000AN Desktop Computers with Windows XP. I know these are a discontinued line, but good secondhand ones would be acceptable. Do you have any ideas? Otherwise any computer...
Hi
I suggest you register with www.alibaba.com and enter:
"6 pcs. 2nd User Compaq CQ2000AN XP Desktop Computers with Warranty"
You will hopefully get e-mails from suppliers all over the world.
Please Note that this model also seems to have the same dimensions (see image below:
Compaq CQ1020UK
Good Luck.
I hope this helps.
If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Sep 02, 2011 | Computers & Internet
Volume of cube whose side 11cm
1331 cubic centimeters (just about 1 and 1/3 litres)
Feb 01, 2011 | Kitchen Ranges
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Ricoh SP C410dn Paper only prints 11cm and stops in the Bypass T
do not use ohp film in this device as it will jam due to the use of optical paper sensors unless your ohp has a paper backing. you can set up the bypass tray for thick paper type to increase fuser temp to get better fusing etc
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Wghich tray do you put the envelopes!!
pls u check this seting in ur designing software.
Jun 24, 2008 | Xerox DocuColor 12 Color Copier
Pagesetup Sato CX400 - 2,5x11cm(Hight,width)
Install the software label gallary which has come with Printer CD, design the label over there. It will work
May 08, 2008 | SATO CX400 Thermal Label Printer
32 people viewed this question
Top In Office Equipment & Supplies Experts
bobwin
J.D. Browning
J.D. Browning
roeb
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
