Question about The Audio Players & Recorders
I still have not received an answer to my question?? What are the correct codes for the dsd 1131. 1-6 and 7-18 none are responding to my input.
How to remove code set 3 for the remote control panasonic bd-45
It seems the best way to "remove code set" is to overwrite it with a different code set.
(From the Owner's manual for the Panasonic DMP-BD45)
STEP 6 :
Reprogramming the remote control
Change "Remote Control Code" (-> 28) on the main unit and
the remote control (the two must match) if you place other
Panasonic products close together and it responds to this
remote control.
You can operate the TV or amplifier/receiver using the unit's
remote control.
1 For televisions
Input the code (-> 37) with the numbered
buttons while pressing [? TV POWER].
For amplifiers/receivers
Input the code (->37) with the numbered
e.g., 0001: [0] -> [0] ->[0] -> [1]
2 Test by turning on the television or
adjusting the volume of the amplifier/
Feb 20, 2016 | Panasonic Televison & Video
DSD-3400 not responding
Dell System Detect. Remove it or disable it from running at startup. Dell will reinstall it if needed. Hopefully with a better version.
Feb 22, 2014 | Dell Black Inspiron One 2320 All-in-One...
What is DSD-3400 not responding
It has to do with Dell System Detect, a dell program.
Dell System Detect automatically detects system information in order to provide a customized support experience.
Copyright 2012 Dell Inc. All Rights Reserved.
Dec 18, 2013 | Computers & Internet
Free to Air on a Dstv
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
Kenwood vr-5900 no sound
Check you settings on the receiver. get into the menu of the unit and check the "Audio" settings. if you can choose by specific input, select "Digital" otherwise, select "Auto" that should correct the problem. If you still have a problem, post a comment and I can help you troubleshoot some more.
Jul 22, 2009 | Kenwood VR-5900 Receiver
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
I like the look and price of the Marantz SR 6003 receiver, my only question being whether it suppports DSD data output from a SACD player like the ONKYO like the OPPO DV-980h. In other words can it receive...
Downloaded the user manual for the Marantz SR 6003 A/V Receiver. In this it stated that if a SACD player was connected to the SR 6003 with an HDMI interface earlier than 1.2 then the digital data from the SACD could not be transferred over the HDMI cable to the SR 6003. This implies, but does not confirm, that if a SACD player does provide a digital output on an HDMI 1.3 interface, then SACD audio data can be transmitted to the SR 6003 and, presumably, decoded and converted to 6 analogue streams which are then amplified and deleivered to the (6) analogue output terminals.
I'm fairly sure that the native DSD data from the SACD has to be converted to PCM before transmission over the HDMI interface which is better than nothing. What I was hoping for though was for the data to be transferred in DSD and converted in the SR 6003 directly to analogue, avoiding two intermediate conversions. This ideal solution can be done by only a few SACD/ A/V Receiver combinations, which is silly considering that it is also the simplest. One example, which has made a big impression amongst high fi enthusiasts, is the OPPO DV-980H Universal DVD player (plays any audio or video disc and costs almost nothing) and the Integra DTC 9.8 home theatre processor.
Jan 14, 2009 | Televison & Video
No video
Is the video cable composite or s-video? the output from the receiver to the sets line input (1,2,3,s-video) must be the same on most receivers. If the game console uses composite (yellow rca connector) to the receiver, the same cable must be the same from receiver to TV. Some receivers do "up convert" to s-video or to Progressive scan (red,green,blue rca connectors) and do not follow this rule. Yor set needs to be switched to the correct input as well. None of the receivers I have services thus far hve the 75ohm cable lug for RF. Check all the cableing and repost if you find something new or different.
Jun 06, 2007 | Panasonic SA-HE70 Receiver
27 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
