Question about PfaFF Sewing Machines
How to thread pfaff 9020 - PfaFF Sewing Machines
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Try this site:
Posted on May 09, 2017
I need a video on how to thread a pfaff hobbylock 4842 serger
Pfaff has a video on threading the Hobbylock 4842 here: . You need Adobe Flash Player available on your browser. Enter the tutorial, the link is below the Quick Help paragraph. Then choose the correct machine (from the links across the top). Then use the drop-down menu to choose the stitch that you will be sewing for the appropriate threading video. Then click on the appropriate thread (below the video window) to see how to thread that section of the serger. (For two-thread stitches, you will see two options are greyed out.)
I hope this helps.
Jun 14, 2017 | PfaFF Sewing Machines
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Pfaff 1471 threading instructions
Hello Patricia P. Thomas
Download a free Pfaff 1471 Manual here
The threading instructions are quite simple to follow.
Please let me know how this works out for you.
Happy Stitching
Feb 27, 2017 | PfaFF Sewing Machines
How to thread a pfaff 2042 machine
You might try contacting Pfaff Support:
Machine Support
May not be your model, but frequently machines thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading.
Threading Pfaff Sewing Machine Select mov
Pfaff quilt style 2042 manual
FAQ Knowledge Base
Dec 17, 2016 | PfaFF Sewing Machines
Thread caught in pfaff 1475 shuttle
Spray a little WD40 on the broken thread, it makes it easier to pull out, also use dental picks to get in there.
Mar 21, 2014 | PfaFF Sewing Machines
Threading a pfaff number 30 has some threading diagrams
contact pfaff for a manual
Apr 18, 2012 | PfaFF Sewing Machines
How to thread a pfaff varimatic 6085 has some threading diagrams
try youtube & ehow for video's on threading the machine
try pfaff customer service for a manual
Apr 15, 2012 | PfaFF Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
Threading a pfaff 9020 sewing machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Jun 18, 2008 | PfaFF Creative 7570
Sewing Machines Logo
44 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
