13.8 KILOGRAMS CONVERTED INTO LITRES - Office Equipment & Supplies
How many kilograms of sawdust is 2000 litres?
I think the only real way to determine the answer is to fill a 1 litre container with sawdust, weigh it and then multiply that weight by 2000. Good luck
Oct 05, 2016 | Cars & Trucks
1 lb 60z what is mean.pls answer me
What's the question?
Since one pound is sixteen ounces, 1 lb 60 oz is 4 lb 12 oz.
Aug 17, 2014 | Cars & Trucks
13 kg to litres
Kilogram is a measure of mass while litre is a measure of volume. There is no direct conversion between them. 13kg of gold will take up about two-thirds of a litre while 13kg of water will take up 13 litres.
Oct 09, 2013 | Office Equipment & Supplies
How many kilogram of oil engineneeds a Nissan murano 2004?
In the United States we don't use Kilograms as a measure of oil we use Quarts. Your country uses Litres wherever you are! THe MUrano uses 5 quarts of oil...you convert it to litres and you get .95 litres = one quart. Just use 5 quarts and all will be OK.
Jan 02, 2013 | 2004 Nissan Murano
7 pints equals what in metric three quarters of a pint equals what in metric half an ounce equals what in metric one and a half pounds equals what in metric 2 pints equals what in metric
Metric what, Liters, milliliters?
1 1/2 pounds converted to what grams, kilograms?
Your answers whatever the values are can be found from any of hundreds of online converters.
You pick the value that you want converted and the value you want it converted to.
One that will work is:
http://www.onlineconversion.com/volume.htm
Good luck, thanks for using FixYa.
Mar 03, 2011 | Office Equipment & Supplies
In 3 buckets, two Buckets filled with 20 litres of water, first- 19 litres capacity(max) second- 13 litres capacity(max)-Filled third- 7 litres capacity(max) -Filled i need to fill 2 buckets with 10...
Assume the following:
B1 = 19 litres capacity
B2 = 13 litres capacity
B3 = 7 litres capacity
B2 and B3 are full. The answer is:
1. Pour 2 litres from B3 to B1
2. Pour 8 litres from B2 to B1
3. Pour the remaining 5 litres in B3 to B2
Another answer:
1. Pour 10 litres from B2 to B1
2. Pour 7 litres from B3 to B2
In both answers you will get 10 litres in two buckets.
Rate if this answer was helpful.
Thanks
Oct 22, 2010 | Computers & Internet
What volume in liters does a tank hold it is 120cm x 120cm x 3ocm
  • 9-10 litres per minute for <= 125 litre capacity
  • 12-13 litres per minute for 160 to 400 litre capacity
  • 15-17 litres per minute for >= 500 litre capacity
  • Apr 03, 2010 | Heating & Cooling
    Convert 6 gallons to kilograms
    Gallons is a liquid measurement and Kilograms is a weight measurement and these are not a compatible conversion.
    If you want to convert gallons to litres then multiple gallons by 4.54 to get litres. (ie there is 4.54 litres to 1 gallon)
    Jan 11, 2010 | Online Double Conversion 1500VA 1050 Watt...
    Anyone solve the pitchers in puzzle 78
    1) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher. (leaves 7 litres in Pitcher 16)
    2) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher. (leaves 2 litres in Pitcher 9)
    3) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
    4) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
    5) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 5 litres in Pitcher 16)
    6) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 4 litres in Pitcher 9)
    7) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
    8) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
    9) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 3 litres in Pitcher 16)
    10) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 6 litres in Pitcher 9)
    11) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
    12) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
    13) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 1 litre in Pitcher 16)
    14) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 8 litres in Pitcher 9)
    15) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (Pitcher 16 also has 8 litres)
    YOU NOW HAVE 8 LITRES IN THE 16 & 9 LITRE PITCHERS.IN 15 MOVES.
    Apr 24, 2009 | Nintendo Professor Layton & the Curious...
    32 people viewed this question
    k24674
    jasbo
    jasbo
