Question about kawasaki Garden
I got a lx188 kawasaki 17.5 at first the instrument panel lights worked and it started fine so I was blowing it off and now instrument panel light want cm on and mower just cranks over and want start
MrScary66613
  • 1990 Answers
SOURCE: instrument panel not working
Look in the Fuse Relay box under the Hood and Replace the Guage Relay. Should get it Fixed.
Posted on Jan 22, 2009
  • 31 Answers
SOURCE: instr. panel and running lights fuse blow when headlights turn on
Do yourself a favor before taking to a dealer. Open the hood and find the fuse box. It will be on the firewall on the drivers side. Open it and fine the low beam relay. Finding it is easy. If you open your owners manual and look up relay in the index in the back of the manual there will be a listing of the relay locations. If you dont have the manual any more. A relay is a black or grey box. There are two diffrent types. The types look like a square and one looks like a rectangle. You are looking for the rectangle. The low beam relay is in the row of rectangle relays closest to the driver's side fender. Remove the two closest to the windshield. The one closest to the windshield is for high beam. Take that one and place it where the low beam is.If that fixes it go to an auto parts store and buy a replacement relay. Then try the lights. Let me know and good luck !
Posted on Mar 14, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a Deere LX188 mower, while mowing the
you need to check the seat switch first then have the park brake switch looked at.is there power to the starter relay?
Posted on Jul 23, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Posted on Nov 13, 2009
SOURCE: instrument panel lights don't work
please advice, have you solved the problem? I have the same one on my Sebring. Many thanks.
Posted on Apr 06, 2010
2004 Kawasaki ZRX 1200 R ignition lights not working
Hi, Stephen if some or all of your instrument cluster goes dark/blank immediately upon startup or a few minutes later riding down the road the usual suspects are:
1. Blown instrument fuse.
2. A bad ground in the instrument circuit.
3. Faulty wiring before or after the fuse.
4. Faulty wiring or connector between the fuse and the instrument cluster.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Thread No start condition 2002 ZRX1200R
http://www.zrxocboard.com/board/archive/index.php/t-42209.html Kawasaki ZRX1200 ZRX1200R ZRX1200S 2001 2007 Service Manual Download... $15
OEM Parts for Kawasaki
2004 Kawasaki ZRX1200 Owner Manual
Apr 30, 2018 | 2004 kawasaki ZRX 1200 R
2007 Kawasaki Z750 no display
Hi, Phil/Fraser if some or all of your instrument cluster goes dark/blank immediately upon startup or a few minutes later riding down the road the usual suspects are:
Blank dash
07 cluster blinking my fuel gauge and the word FUEL Any ideas
Kawasaki Z750 ABS Service Manual
2006 Kawasaki Z750S Owner Manual
Feb 28, 2015 | 2007 kawasaki Z750
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
Fuse keeps blowing dash lights and tail lights dont work jeep cherokee sport 1999
There are several fuses involved. I need to know which one(s). As for the taillights, the primary power source is 20A fuse 17 in the power distribution center. The tan/blk wire connects to the headlamp switch which, in park position, applies +12 volts through 10A fuse 7 in the junction block to the left tail light. The headlamp switch, in park position, also apples +12 volts through 10A fuse 23 in the junction block to the right tail light.
I need to know which fuse is blowing the instrument lights so you will have to follow up
Sep 07, 2012 | 1999 Jeep Cherokee
John Deere LX188 17hp Kawasaki eng. Battery light constantly on; PTO for mower intermittent; will shut down after running for about an hour(battery discharge?). Suspect voltage regulator. Can't...
I have same problem with my lx188 battery light stays on and will run fine at idle, then I can mow for about 15mins then it powers down and run rough, and battery light dims down.
???? Is it the voltage regulator ?
May 06, 2011 | Garden
I have a 2002 Chevy Avalanche 2500 with dash lights out. Not only did these lights go out but the power locks also stopped working at about the same time. Not sure if that is coincidence or what. All the...
Factory repair manual step by step testing procedure for Interior Backlighting Inoperative. In your course of testing let me know if you need location for anything .
Turn ON the parklamps.
Ensure the panel dimmer switch is at maximum illumination.
Do the illumination lamps operate normally?
YES - Go to Testing for Electrical Intermittents in Wiring Systems
NO - Go to Step 3
Is only one lamp inoperative?
YES - Go to Step 4
NO - Go to Step 6
Test the instrument panel lamp supply voltage circuit of the inoperative lamp for high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 17
NO - Go to Step 5
5
Test the ground circuit of the inoperative lamp for high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 11
6
Do the park lamps function properly?
YES - Go to Step 7
NO - Go to Park Lamps Inoperative
7
Inspect the ILLUM fuse.
Is the fuse open?
YES - Go to Step 12
NO - Go to Step 8
8
Connect a test lamp between the ILLUM fuse and ground.
Does the test lamp illuminate?
YES - Go to Step 14
NO - Go to Step 9
9
without disconnecting the switch, connect a test lamp between the instrument panel lamps dimmer switch signal circuit at the headlamp and panel dimmer switch and ground.
YES - Go to Step 13
NO - Go to Step 10
10
Inspect for poor connections at the harness connector of the headlamp and panel dimmer switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 16
11
Inspect for poor connections at the harness connector of the inoperative bulb. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 15
12
Repair the short to ground in the instrument panel lamp supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Replace the fuse.
YES - Did you complete the repair?
NO - Go to Step 17
13
Repair the open in the instrument panel lamps dimmer switch signal circuit between the switch and the fuse. Refer to Wiring Repairs in Wiring Systems.
Go to Step 17
14
Repair the open in the instrument panel lamp supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 17
15
Replace the inoperative bulb.
Did you complete the replacement?
Go to Step 17
16
Replace the headlamp and panel dimmer switch. Refer to Headlamp Switch Replacement .
Go to Step 17
17
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Sep 10, 2017 | Cars & Trucks
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
The lighting in the instrument panel in the 94
i hate light bulbs they allways blow at the worst time
get out your chiltons book and start the dissassembly
Jan 05, 2010 | 1994 Ford Taurus
Garden Logo
51 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
