Question about Refrigerators
Fridge model r831fwjndss light on pc board flashes #18/minute.compressor does not run
3 Suggested Answers
refritech08
  • 149 Answers
SOURCE: compressor not running, front display flashing "CF"
have you tried to see if your getting voltage at compessor?? it sounds like relay/overload is bad have you replaced it?
if not, try that i'm suspecting that's the problem
Posted on Apr 23, 2008
t0ny_pars0ns
  • 5412 Answers
SOURCE: #18 flashes a minute. model r831fwjndss
This is not achievable, AFAIK - for multiple flashes of extremely short duration, you will need to look at expensive professional equipment
Posted on May 08, 2017
May 08, 2017 | Cameras
We recently had a power outage, now the interior light is flashing and the fridge is not cooling
Try resetting the fridge and freezer temp, fridge 4 deg C freezer -18 deg C turn the unit off at the power socket leave for a minute then turn on be fore resetting.
Mar 03, 2016 | Liebherr Refrigerators
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Samsung Refrigerator RS261MDPN starts up when plugged in for about 10 seconds then stops. The center light of the freezer temp indicator blinks. compressor does not run in this mode. Also,is the...
Samsung fridge wont start compressor right away. There is delay, so when you plug fridge in it take 15 - 20 minutes to start.To check if fan is running, you need magnet. Place it on top of door hinge. Open door and if lights are out, you are in wright spot. Take magnet of to test if lights come on. Now put magnet back and if fridge fan is running you can feel it how it blow from different outlets inside of fridge .
Jul 23, 2011 | Refrigerators
I have a GE REfridge that stopped running....
The compressor never runs out of freon - unless you have a leak somewhere, which is rare - and besides, your compressor motor would be still running but you would not get cooling - the most common problem associated with this is control board failure, so compressor does not start at all. Try unplugging the refrigerator for a few minutes and plug in again - see if this resets the control board - if problem persists or comes back you will need to call service and have them check the control board.
Before doing so, try unplugging and plugging back in after a few minutes, it might get things started again - if you have a manual knob for your cold control try setting the dial to off, then turn it back on all the way until you hear a "click" sound to confirm your thermostat is working properly - if you hear the clicking on the thermostat area, but compressor motor does not come on, call service.
Sep 04, 2009 | GE GSS20IEP Side by Side Refrigerator
My refrigerator (RB1855) runs excessively long. Down time 15 minutes and run time 20 minutes. Noise comes out from the compressor. Even raiseed the temp setting (-18 to 17 and 3 to 4) when it is running...
There are about four different versions of your model. If you like I will send you the manual and we will work together as this refrigerator is very complex. Let me know, Thanks, Sea Breeze
Jul 11, 2009 | Samsung Refrigerators
Clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Apr 27, 2009 | Refrigerators
I moved our 18 month old samsung fridge freezer Model SR281NW and one week later it has stopped working. The freezer fully defrosted and the fridge, even though it has the light on, is not cold
Is the compressor trying to run at all. Are any sounds coming from the area of the compressor? Like a hum and a click sound in that order? If the compressor is cold to the touch it could be a control problem. If the compressor is cold there are two things that shut its power off. The thermostat which controls the temperature or the defrost system. If the compressor is hot the problem is compressor related.
May 18, 2008 | Samsung Refrigerators
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
