What are the channel codes for dsd 1131 from channel 1-6 and then 7-18. Cannot find correct codes anywhere please help.
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
Sep 05, 2016 | Cooktops
SINOTEC LOOSING SIGNAL ON AV ONLY DSD PLAYS THROUGH VGA WITH BLUE BACK GROUND PLEASE HELP
Check the AV connecting cable for any internal conductor break. Replace it with an other good one, and check.
Dec 02, 2014 | Televison & Video
Codes for dsd 1132
275,270,271. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 18, 2013 | Gemini 1 Device Universal Television...
Is it possible to unlock dstv channels by entering the codes?
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 27, 2012 | Cell Phones
SONY Push Power Protector DAV - DZ610
Shahid, my Sony DAV-576WF is getting push power protector (SD detect), think it might be one channel blown, I do have the Schematic Diagram (service manu book) and ee knowledge with tool, could you give me a hand on fixing that when you got time?
It is no a fancy receiver but it does play SACD/DSD, that's the part I like
my email is yuyi429@hotmail.com
Nov 07, 2011 | Audio Players & Recorders
Error code FTE1
dsd Sorry to read about your problem, I hope this helps you out.
you have a keypad issue
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | KitchenAid KGRS807SSS Gas Kitchen Range
Free to Air on a Dstv
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
Codes for telewest 20 jan
I just re inputed the old numbers and the channels came back on, as I couldn't find new codes anywhere, so I thought I would try with the old ones again
Jan 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
