Question about Alcatel Cell Phones
I have an alcatel powered by android and my phne stopped taking a charge ,it has a battery symbol and 0%,it was vibrating every few seconds on charger but now won't turn on
  • 31 Answers
SOURCE: Symbol MC35 refuses to charge
Try loading the latest Operating System files from Motorola. If that doesn't help you can try getting a new battery. If that doesn't work it will need to go to repair.
Posted on Jun 30, 2009
  • 1043 Answers
SOURCE: Battery charging for few seconds before it stops
Either the electronics in the charger or the battery have failed. If you still have any warranty left on the laptop call Dell support and they will assist you in identifying which one has failed.
Posted on Sep 17, 2009
SOURCE: Fuji Fin Pix Battery Charger BC-45B when charging
HOW I KNOW THE BATERY IS CHARGING....WHAT IS COLOUR OF THE INDICATER WILL INDICATE
Posted on Dec 06, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: When I put the charger in my iphone it beeps and
Sorry to read about your problem, I hope this helps you out.
Due a full reset on the phone, should correct the problem
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
lexzy80
  • 943 Answers
SOURCE: My Nokia E52 won't charge.
This problem can be traced to only a few causes. Listed below are the causes and possible solutions to this problem.
1. It is most likely that your battery may not be having proper contact with the terminal that does the main work for charging it. The three terminals that can be seen perform different tasks and as such, when that which is responsible for drawing power from the battery to operate the phone is in good contact, the phone might work normally but refuse to charge when that which is responsible for charging the battery is not properly in place. The easiest way to solve this problem is to turn off your phone and remove the battery. Try to clean the battery and all of the phone's terminals without using any liquid and then re-insert the battery.
2. Your phone may be having a faulty charging port and as a result cannot perform the complete task of charging the battery. In this case, the only thing that can be done is to try to dust the charging port and try to charge again. If this actually happens to be the exact problem, you might have to take the phone to a repairer so as to open up the phone and do a proper scan through on the phone.
3. lastly and most unlikely, the battery may have been damaged and needs replacement. This also depends on how long the battery has been in use. If it has been in use for more than 3 years, it is advised you replace the battery. Also, you can try connecting the phone to another power source to see if that helps too.
Hope this solution was helpful?
Posted on May 24, 2011
My alcatel onetouch evolve died a while back and when i finaly got it charged up, it wont power on, i held down the power on button and nothing happned, can someone please help me out here? thanks for...
First is the battery ok and fully charged. try and switch it on while hooked to the charger, you may have to hold the button down for a few seconds . if it comes to life now the battery is at fault. If nothing have the switch checked out.
Dec 25, 2014 | T-Mobile Prepaid Alcatel One Touch Evolve...
How do I fix my android alcatel one touch fierce whnen the right end of the battery is lifting up
you will have to replace the battery (take note that it is very dangerous to use a broken battery especially during the charging of the battery you run the risk of the battery exploding) I strongly suggest you get a replacement battery
Nov 10, 2014 | ALCATEL-LUCENT USA INC One Touch Fierce 4...
Hello, my android jellybean nextbook won't turn on. The red light will glow but no charging symbol when connected to a charger. Please help. Thank you for your time.
Try holding the power button down for 10-15 seconds, then release.
Is it possible that perhaps your charger isn't working, and therefor not charging your tablet (and the battery charge is depleted?)
Nov 02, 2014 | Tablets & eReaders
I have a android jellybean 4.2 tablet when you put it on charge comes up with charge symbol then when you try turn it on it comes up with the android symbol filling up with jelly beans then lights word for...
Check by replacing the battery. If battery is weak [in terms of current storing capacity], the phone will show; as the battery is fully charged, but, when the software starts to load, the voltage of the battery will go very low than normal. If so, the fault you indicates here can happen. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 08, 2014 | Tablets & eReaders
System reboot problem
what kind of phone is it? Cell phone? Android or iPhone? What network WiFi are you trying to connect to? If iPhone you need to put your phone in recovery mode, and reset it using iTunes. If it is Android, remove the battery without shutting it off, wait 30 seconds, then re-insert the battery, and power it up. Try to reconnect. If message re-appears, your android phne may be finished.
Sep 16, 2013 | Computers & Internet
My alcatel OT-906 phone is not opening
Hello My Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 26, 2012 | MOBILESW Alcatel OT-906 2.8" Resistive...
Have put it on charge, but will not switch on battery symbol with zig zag through flashing every few seconds
either your battery is faulty or you power cord has a short. take out the battery and run the computer with just the cord in. if it runs fine then it is the battery. does your battery hold a charge?
Dec 25, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
Can't use the phone
your battery is probably bad, take your phone in to where you bought it and tell them, they will probably replace it for free. or go to ebay.com and search for
Alcatel OT-C701 Battery, probably not more than 20.00 shipped
Jun 03, 2009 | Alcatel OT-C701 Cellular Phone
Cect p168C will not power on
  1. Turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  2. If that doesn't work, connect it to the iPhone charger and let it charge for at least 10 minutes. Note: iPhone 3G does not support FireWire and will not charge from any FireWire-based power source.
  3. If that doesn't work, toggle the ringer switch to see if the unit vibrates. If it does, it could be that iPhone is getting power, but is not displaying any image. (see "Display has no backlight or dark screen" below for further troubleshooting.)
  4. While connected to the iPhone charger, try to reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPhone until it is fully charged.
Oct 16, 2008 | Apple iPhone Smartphone
Cell Phones Logo
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
