Telefunken TLCD-46FHDA HDMI port flty. According to my local TV service agent they cannot find a replacement main board to repair this fault. Any advise, ie. where can I find spares in South Africa?
evwood
  • 50 Answers
SOURCE: HEAD REPLACEMENT FOR FELECTRIC TWHERE IN SOUTH AFRICA DURBAN AREA
Go on the WEB and contact Ryobi. You should be able to obtain a replacement.
Posted on Jan 03, 2009
SOURCE: Samsung syncmaster 241mp
have you managed to get this repaired? i have the same problem...
Posted on Jun 21, 2009
  • 136 Answers
SOURCE: Hi, my charger is faulty and I am battling to find
http://www.amazon.com/Braun-Charger-Contour-CruZer-Freeglider/dp/B000IANLXK?tag=thank-20
you can buy the charger from above site. please click on the link..
Posted on Jan 18, 2010
Grubhead
  • 5056 Answers
SOURCE: Describe your Panasonic NV-SJ205 VHS
Have a look at the website for Prime Electronics. They say the stock spares for Panasonic. They have a site on the Gold Coast!
Posted on Oct 12, 2010
SOURCE: LG GR267EHF Double door fridge / freezer side by
EL LADO DEL REFRIGERADOR NO ENFRIA Y LA FABRICA DE HIELO NO CONGELA
Posted on Mar 08, 2011
Vizio tv HDMI ports stopped working TV antenna port works fine, Remote control works. Just no HDMI
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 01, 2017 | Vizio Televison & Video
TELEFUNKEN TV TLEDD-50FHD--ON SWITCH ONLY A FLICKER OF BLUE SCREEN THEN BLANK.IS A PC BOARD FLTY?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 17, 2016 | Televison & Video
No hdmi port works on Westinghouse 26 inch tv
Mar 23, 2016 | Westinghouse Televison & Video
Which part do i replace on my Toshiba 47hl167 TV to repair my faulty HDMI ports?
http://electro-medical.blogspot.com/
Jan 26, 2016 | Toshiba REGZA 47HL167 TV
Replaced board that has hdmi ports and the tv still has high power coming out of cable in put port and has burned out hdmi inport
Fault to the main power supply regulator section. {AC leak} Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 15, 2015 | Televison & Video
Telefunken TLCD-19W set tripping there's nothing wrong with power supply adaptor
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Apr 23, 2014 | Televison & Video
No signal HDMI or DVI
Do a firmware update. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 26, 2014 | Initial Televison & Video
Telefunken lcd tv
http://www.alibaba.com.
Try the above link for the availability of the mother board.
Gopakumar Gopalan Google
Mar 10, 2014 | Televison & Video
Telefunken lcd tv
Sounds like a main board fault. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 11, 2014 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
