Question about Refrigerators
Model r831fwjndss light on pc board flashing compressor not running
3 Suggested Answers
refritech08
  • 149 Answers
SOURCE: compressor not running, front display flashing "CF"
have you tried to see if your getting voltage at compessor?? it sounds like relay/overload is bad have you replaced it?
if not, try that i'm suspecting that's the problem
Posted on Apr 23, 2008
t0ny_pars0ns
  • 5048 Answers
SOURCE: #18 flashes a minute. model r831fwjndss
This is not achievable, AFAIK - for multiple flashes of extremely short duration, you will need to look at expensive professional equipment
Posted on May 08, 2017
May 08, 2017 | Cameras
Power is on but don't run
Is the red light flashing if so count the #of flashes it shows consecutively.then Google that #of flashes on that model you will get your answers. If just solid red you may have an issue in the board or compressor
Aug 11, 2014 | Haier Freezers
Kenmore AC window unit model 253 70151 cuts on and off.
Circuit board could be the problem but compressor needs to be checked and there might be a loose electric connection or high voltage causing the ac to trip
Apr 04, 2014 | Heating & Cooling
The unit either encountered a brown out or a surge which burned up the board for the condenser. It had black marks on the board and the indoor unit was flashing. Replaced the board and the unit is still...
After replacing the burned condenser board, check also the entire condensing unit if still ok ( compressor and fan motor). If the light inside the indoor unit is still flashing, the timer is still not giving signal for the compressor to start. Adjust temperature and wait for 3-5 minutes. It light continue flashing, there is something wrong with the indoor unit control.
Sep 02, 2011 | Sanyo Split System Air Conditioner
Defy side by side 2002 model all lights on control panel are flashing and the freezer motor kicks in and stops in short intervals . is it the pc board.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Refrigerators
Have an lg neo plasma that turns off at 6pm till 8 pm. no fault codes are showing. have reset remote no timers are on. models is S30awn ueo. outdoor pc board has a continous green light and red light that...
DC Peak (IPM Fault); Compressor malfunction,IPM Fault;
Check Point
1. Check the wire connection. (U,V,W)
2. Check the load condition. (Refrigerant, Pipe length, ...) Adjust the load condition
3. Check the electricity leakage of the compressor. Normal : Over 2Mω.
4. Check the resistance of compressor. Normal : 0.65ω(INV), 0.8ω(Cons.) No difference at each terminal.
5. Check the insulation from water at IPM part. Check the trace of water.
6. Check the IPM circuit.
Call repairman to check the above. Thanks.
Feb 04, 2011 | Heating & Cooling
Model dss25pfmdww quit cooling
We do need to check the PC board part number WR55X10656
Jul 24, 2009 | GE GSS25JEM Side by Side Refrigerator
Outdoor unit does not Run
If you manually push in the contactor does the compressor start? If so, then it probably is the defrost board. If not, then do an ohms check on the compressor to make sure it hasn't failed.
Mar 30, 2009 | Haier Heating & Cooling
Compressor not running, front display flashing "CF"
Apr 23, 2008 | Kenmore 44103 Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
