A router by default is open to all network.To set a key you need to go into a browser and type 192.168.*.* depending on your router it will differ from others.Then once into your router setting you can create a password and wep key according to your wants.It is not a difficult task but you need some patience and a bit of struggling with some google help will solve this problem.
Access your router with following link.
http://192.168.1.1 or
http://192.168.0.1
thsese are defaults ip to access it.
then type user name as "admin" and password as "admin" or blank or "password"
then go to wi fi security encryption and get encryptipn code it is your WEP code.
SOURCE: WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
SOURCE: Wireless connection
NETGEAR Technical Support Engineer 1. access 1st the router's setup page * open up a browser * http://192.168.1.1 or http://www.routerlogin.com/ 2. go to wireless settings under setup if you have a wireless phone at home change the channel of the router, make sure they dont have same channel 3. change the mode of the router to w/c your laptop's wireless adapter support (eg. b only, g only ) 4. try to change security option wpa instead of wep (make sure your laptop's adapter support it) 5. change SSID (note: if you've change the SSID of the router, remove the profile on your computer under preferred networks 6. change your passphrase 7. Disable Advanced 108Mbps Features 8. Disable Setup Access List (it can be found in wireless settings under advance) 9. upgrade firmware of the router * before upgrading make sure you backup the settings (go to backup under maintenance) * if latest firmware is installed * flush firmware (flushing it is just reinstalling even if the latest firmware is installed) 10. power cycle frequently (turn off for 10 seconds then turn it on again) 11. If all of these didnt work call your laptop manufacturer for help 12. call gearhead -> 1-888-615-3488 13. or call our technical support 1-888-netgear lucky if you got me ***caesar *** NETGEAR technical support engineer
SOURCE: WEP key
where do you find this wep/wpa key. because ive been trying to connect to my home router and it asks me for a wpa key and i dont know what it is.
SOURCE: can remember wep or wpa key for wireless router (microsoft mn-5
Fastest solution is to connect to the router with a cable, login to the admin screen of the router, select the wireless tab or screen and you should find the key. Write it down and then update your laptop configuration with the key.
Good luck and thanks for using FixYA.
SOURCE: where is the wep key located on my virgin router
Connect your desktop computer to your Belkin router, and access the router's built-in web-server software. Then, run the "Wireless Network Setup Wizard", to configure the router's wireless networking capabilities. As part of that process, you will be required to _create_ a "WEP-key" value. Use that value when configuring the wireless capability of your PS3.
