Question about Star Washing Machines
Washing machine stopping on cycle star sign lit up
dididsaythat
  • 291 Answers
SOURCE: washing machine gone crazy
Does the timmer advance at all? Timmer motor. on timmer if timmer not advancing.
Posted on Sep 11, 2007
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
beltronic205
  • 1474 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Brand new front Load GE washing machine stop at rinse cycle
Check that the Cold water valve faucet is open. Perhaps the earlier vibration problems have caused a wire to come off the water valve connections inside the machine.
Sep 30, 2017 | GE Energy Star WCVH6260F Front Load Washer
I have a WF220, 1200 spin washing machine (3.5 years old and very little use) which does not complete the washing cycle. Each light comes on as the programme progresses until all the lights are lit...
You may find that the internal filter is blocked & that by stopping and starting the machine you are giving it extra time to complete the drain cycle. The filter is located at the bottom rear of the machine & is secured by a large hose clip to the bottom of the drum. Try filling the washer with no clothes in & then switching to the drain programme to see if the water drains properly
Nov 03, 2008 | Washing Machines
My Bosch WFF 2000 washing machine goes through its cycle and then leaves the on/off button lit, the door button lit and the pre-wash button flashing; also the door will not open until you turn all the...
The problem turned out to be foreign objects in the pump that stopped the machine from draining; the solution is simply to open up the pump and remove the objects!
Sep 09, 2008 | Bosch Washing Machines
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
Top Star Washing Machines Experts
Are you a Star Washing Machine Expert? Answer questions, earn points and help others
