Question about Power Acoustik Car Audio & Video
Power acoustik LT980-2 amp is stuck in protection mode inside is pristine no signs of shorting or fried circuts checked the connections & fuses what else is there to check that i might b missing
alicantecoli
  • 22306 Answers
SOURCE: 1998 Ford Escort Radio fuse short circuting
try disconnecting *** lighter
Posted on Nov 18, 2008
SOURCE: my amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Posted on Feb 07, 2009
etirbynnor
  • 655 Answers
SOURCE: audiofonics adf-241 no power all wires connected fuses ok.
Hello pimprascalz,
Many amps will go into protect mode if one of the speaker wires is shorted or grounded, or if the voice coil(s) are defective. Try disconnecting the speaker wires one at a time and see if the amp still goes into protect upon power up. Likewise, some amps will go into protect if one of the inputs is grounding out. Again, to troubleshoot, disconnect them one at a time and try the amp. Next, make sure that the amp itself is not grounding. Most amps need to be mounted to a nonconductive surface. If the case contacts the frame of the vehicle, it can cause a problem. If the problem is not in the speaker wires or the input cables, the amp case is not contacting the vehicle frame, and you have checked your power, ground and turn-on leads, then the amp itself is probably faulty.
Hope this helps.
Posted on May 19, 2009
etirbynnor
  • 655 Answers
SOURCE: power acoustiks amp wont get off protection mode
Hello nfox1987,
First you need to determine if the amp is defective or if something else is causing it to go into protection, most often a short in the sub or amp wiring.
Disconnect the sub(s) from the speaker output terminals and the RCA inputs from the head unit, and test if the amp powers up OK. If it does, the problem is in the sub(s) wiring or voice coils, or in the RCA inputs to the amp. Reconnect each one-at-a-time to determine exactly where the short is and repair or replace the defective wiring or unit. If it doesn't power up with the inputs and sub(s) disconnected, the amp itself is most likely defective.
Hope this helps.
Posted on Jul 16, 2009
bigTROY502
  • 129 Answers
SOURCE: Amp in power protect
A blown speaker will trigger the protect mode, sotry to power upthe amp with the speakers disconected, If you are still in protect, then the amp is bad.
Posted on Aug 08, 2009
Power acoustik bafm2000/1d no power coming from channel
HelloAny one channel circuit of the amplifier has any sort of trouble, the amp will go to protect mode. It may be a direct short in it he output circuit. This is the common fault for these type of amps. A through check should be done to find out the reason. You must have sound knoledge in electronics, and experience to do this work by yourself. In most cases, unlike TVs, amps circuits are quite complicated and user cannot do it by themselves. OK.
Dec 19, 2011 | Power Acoustik BAMF2000/1D Car Amp
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2011 | Power Acoustik LT-980/2 Car Audio...
The amp is in protect mode and there is no signs of overheating on the board
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . A thumbs up would be greatly appreciated if this answer is helpful to you
Oct 19, 2010 | Power Acoustik LT-980/2 Car Audio...
I have two amps my power acoustic ov2-1800 stays in protect mode when i turn my car on, and my other amp is a JL Audio and it goes in and out of procect mode randomly??? Any insight???
You have a short. Check all power connections to both amps, all the way back to the battery. Then check to make sure speakers are connected properly
Jun 04, 2010 | Power Acoustik GOTHIC OV2-1800 Car Amp
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
Its in protect mode and i don't know how to get it out it was hitting fine then it just stopped and i looked at the subs and they would posh all the way out then back i don't know whats wrong
overloading your amp try just one sub hooked up and see what happens if it starts working do not bridge your subs use two channels and try again other wise you fried the circut board in the amp some where
Oct 31, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Amp turns on just fine but no sound comes out
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
The red light is on but there is power to the unit. no visible
If the red light is the protect LED, the amp probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 25, 2008 | Power Acoustik SL2-2000 Car Audio...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
Power acoustik ps2-1600 blowing fuses
Generally, this would indicate that the output transistors are shorted (which is generally a relatively simple repair). But an amplifier that never worked properly could indicate that it has a manufacturing defect. Sometimes, it's as simple as a bridged solder connection. Other times, it could be due to a missing component (which may be more difficult to repair).
The first thing you need to do is to check the output transistors. They will typically be the larger devices clamped to the heatsink. If you find any that are shorted (~0 ohms) between legs 2 and 3, you have at least one shorted transistor.
Before you do anything inside the amp, remove it from the power source and read the following page:
Basic Amp Repair
Dec 30, 2007 | Power Acoustik PS2-1600 Car Audio...
Car Audio & Video Logo
88 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
