TRYING TO GET FORMS TO REGISTER WITH TRANSNET ON THEIR DATABASE.
Database registration
Hello Nemutandani,
We need more info if we are going to try to help you..??.what database are you referring to? .... You cannot register for any database on Fixya,
Jul 14, 2017 | Computers & Internet
I want to register with transnet
this is fixya notify transnet for your request
Apr 20, 2017 | Retail Supplies
Sir i need a quick heal(2009) version10.00 SERIAL NUMBER SIR
Even if you get the serial no from here, you can't activate it since it's copyright and your activation will be registered with the quick heal database. I suggest you to buy a new copy or if you've lost the key, you can write to the quickheal using contact us form from quickheal.com. They will ask you for additional payment and will provide you the new key. Good luck.
May 25, 2010 | Computers & Internet
Problem opening Access Database-upgrade from Access 2003 to 2007
if the form "products" really exists, then your office 2007 security settings are not allowing to load macros. Try the following settings:-
Office 2007 has some security settings disabled by default to prevent any harm to your system.
go to trustcenter settings(click the office button at the top left of the office 2007 screen then click Access options, then select Trustcenter, then click trustcenter settings.)
In trustcenter settings, select message bar then select "Show the message bar in all applications when content is blocked" radio button.
Then from macro settings ,make sure to select "Disable all macros with notification" . Click ok twice to close the settings windows and try opening the file again.
Good Luck
Mar 25, 2009 | Microsoft Access 2003 for PC
Database talks to code but code won't talk to database
Make sure you are connecting to the database,then just before you call your sql to insert use an echo statement to display the sql and check it for syntax:-
$sql = 'insert into table1 values('.$no.','.$no.',"block","'.$value3.'", "'.$value4.'")';
echo "SQL ==>" STARTOFSQL<br>".$sql." ENDOFSQL<br>";
Jan 18, 2009 | The PHP Group PHP
Data storage form
If you give me a bit more detail about what you're trying to do, I would be happy to help.
I think you are interested in building a form that will add records to a database. Am I correct?
Tell me the language you are using, and the type of db. I know you are interested in SQL, but perhaps you are using Access.
If I guessed you are trying to create a web form that adds records to a database would I be correct?
The more detail you can offer, the more I can be of help.
Best Regards,
airoff (Alan)
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
C database with formdesigns
You are at least by looking at what you are trying to do familair with far more than the average user. On the other hand you have not supplied the names of what you are doing or as good a description of the problem as might be necessary to pose a meaningful solution. SO....my suggestion is you check faq's at your suppliers website, google the internet with your specific problem, and go to your O/S suppliers website (i.e. the Microsoft knowledge base) for more help.
Jan 18, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
