Question about Samsung Audio Players & Recorders
What sample rate does the Samsung UE43KU6670 TV use for its optical digital output, (e.g.is it 192kHz), and would a cheap Toslink box supporting 24-bit and sampling rate at 32,44.1,48 and 96KHz be OK?
SOURCE: Tascam FW 1804 - Sample rate keeps changing by it's self
Share with you how I solved it? So as you scumbags can go and charge some poor bastard on how how to solve it? Feckin' pathetic!! contact me directly peeps at cass_72 _2003 @yahoo.com
Posted on Jul 15, 2008
SOURCE: mv 8000 input does not switch from optical to analog
U need to reset your parameters.....Goto the  System button and then  press F5.  This will lead you to where you need to press initialize to reset the parameters.  Don't worry it wont delete any of your sounds etc.  I had the same problems.....u will probably have to do it every-time you turn it back on and off.  I think the cause of this is due to it having a previous expansion on it......
"Moshae"
myspace.com/iamdirtysouthmoshae
Posted on Dec 24, 2008
  • 77 Answers
SOURCE: SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
Posted on Feb 25, 2009
SOURCE: Dolby output is Pro Logic II, even though source is Dolby Digital
I know nothing about tivo but dvd player might need to be on bitstream to pick it up.I have to change mine when listening to music. hope this might help.
Posted on Apr 17, 2009
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I'm trying to connect my LED samsung tv to my pioneer amp M-L11 using the digital audio output. Can you tell me please if my stereo system should be able to be support my tv so that i am able to h
Pioneer Amp input is analog. if there is a headphones out
( no model for Samsung LED TV) , connect it , not using your
Fisual Digital Opitcal Toslink Cable.
If you really need to use the TV digital out you may need a Digital
to Analog converter , to be connected on Pioneer XC L11 Aux Input .
Optical is Out only for that model.
Sep 26, 2012 | Audio Players & Recorders
No Sound - Very quiet static/ticking noise
http://ca.asus.com/en/Motherboards/Intel_Socket_1366/SABERTOOTH_X58/
Specifications;
Audio: Absolute Pitch 192kHZ/ 24-bit True BD Lossless Sound
- Asus noise filter
- Optical S/PDIF out port/s at back panel
http://www.asus.com/News/8krSWx1MniBbcCUI/
Ummm,....No.
10 Channel sound (?)
BD stands for Blu-ray Discs
192kHZ/24-bits True BD
The above is a 192kHZ sampling rate with a 24-bit sound output.
REALLY good quality.
However,
Realtek ALC892 is the audio chipset.
http://www.realtek.com.tw/products/productsView.aspx?Langid=1&PNid=24&PFid=28&Level=5&Conn=4&ProdID=284
"The ALC892 provides ten DAC channels that simultaneously support 7.1 channel sound playback, plus 2 channels of independent stereo sound output (multiple streaming) through the front panel stereo outputs."
Oh, 10 DAC channels.
http://en.wikipedia.org/wiki/Digital-to-analog_converter
(I learn something new everyday, lol!)
Regards,
joecoolvette
Aug 14, 2012 | Computers & Internet
How do I get my Samsung TV audio to output though my onkyo tx-sr608?
If it is a relatively new TV you should use an optical digital audio cable. These are often called "toslink" cables. Plug one end into the "digital audio out" port of your TV, and the other into a free toslink port on the receiver (there are two on the back and a third on the front of the 608).
You should then change the settings on your samsung tv to: - turn the digital audio (s/pdif) output on - allow bitstream output over s/pdif - turn the tv speaker off I am not sure which model Samsung you have, so I can't go into great detail, but I'm sure you will be able to find the relevant settings, most likely under "sound" in your system menu.
lastly, you will probably want to use the input assign page of the onkyo on-screen menu to assign whichever input you use to your TV, and change its name accordingly.
Jan 09, 2011 | Onkyo TX-SR608 Receiver
I hava a insignia dvd receiver is-htib102731 and want to know what optical digital audio cord to buy for sound on my tv
gailsplaytim,
That really depends on what audio inputs you have on your tv. Your Insignia has composite audio outputs (Red and White) and digital coaxial and your tv most likely will have at least composite inputs.
The easiest way to connect your dvd to your tv is just to use the composite as you will not hear the difference in sound quality between the two through the speakers built into your tv.
If you want to run digital audio into your tv for a reason such as the tv's audio output is running to another device like a receiver and you want the digital audio to transfer, you need to look at what digital audio inputs you have on your tv. The only digital audio output on your dvd is a digital coaxial. You can buy digital coaxial converters online. If your tv for example has a toslink input, there are digital coaxial to toslink converters relativity cheap online
-Chris.
Feb 28, 2010 | Electronics - Others
Digital Audio out in MACBOOK PRO.
Connect external speakers, headphones, or optical digital audio equipment. The headphone / line output jack accommodates optical digital audio output, analog audio output with a 24-bit, 44.1-192 kHz D/A converter, digital audio output up to 24-bit stereo and 44.1-192 kHz sampling rate and supporting encoded digital audio output (AC3 and DTS). For analog headphone / line output a standard audio cable with 3.5mm metal plug should be used. For digital audio, a standard Toslink cable with a Toslink mini-plug adapter can be used.
You can find the Digital to Analog converted:
http://tinyurl.com/9ms8mv
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Apple MacBook Pro Notebook
Different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
Jan 08, 2009 | Yamaha RX-V461 AV Receiver
221 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
