Question about Nokia 6255i
Mic not working
I do everything like washing,flashing i check from meter every thing is ok but my mic not working i also change d mic 10 times but result is not done so plz give me advise to enabling d mic
Mic not working
Posted on Oct 24, 2010
  • Nokia Master
  • 805 Answers
So i think ur mic ic has corrupt as a result, u had no result.at this time u need go to tecniciation and discuss with his/her. thanks
Posted on Jul 25, 2009
  • forg8u Oct 24, 2010
    please tell me cdma china mobile
  • IT Solution
    IT Solution Oct 26, 2010
    Firstly format your cell phone by using this code *#7370#. but remind that when you format your phone then your former contact no and sms everything will be erase. if unfortunately it doesn't work yet then please open your casing and wipe your mic dust if if has and then check your mic quality still is it ok. if not then please contract with a professional technician. he may check your mic connector or linking additional matter. if ok then may he advice to change your mic. thanks
My Midland just stopped working nothing works anymore
unplug the mic,take a volt meter put the setting to x1 or sound.
first thing , test the fuse to see if its burnt If its ok then check the reverse polarity diode. then if thats ok Touch the positive wire to the radio with the pos.lead then touch the pins on the mic plug.You should get some kind of tone when this is done. If you don't get a sound then go to the rear of the set and touch the neg.lead to the neg wire at the power intake and work towards the front.You should find where the tone stops soon. turn the radio over at this point and check to see if the pcb has a crack in it. There could be a bad spot on the pcb. If you find a bad spot take a piece of jumper wire from another set of course and solder across the break don't leave any wire exposed. the radio should power up
Oct 27, 2013 | Radio Communications
Have a 99v was talking one nite talking great turn it off then back on no modulation check and change mics.still no mod.what should i look for ?
Check the mic gain.
Make sure it is not in PA mode.
Make sure the mic jack in the radio doesn't have a broke or loose wire.
Those are a few things I can think of based on the information given. More information is needed if these will no solve the problem.
Does it turn on?
Does it key up?
If it keys up is there carrier?
How many watts is the carrier?
Are there any mods done to the radio?
Does it have a roger beep installed? What kind?
Does it have an echo board install? What kind?
Did you do the mod or some one else?
What is your SWR?
Is the display flashing when you key it?
Are the displays lit at all?
Did you disconnect the power cord after you turned it off, and reconnect it?
What channel are you keying up on.
Was/is the case off the radio when you tried it or were you working on it at the time of the failure?
What mics have you tried.
are you using talk back?
did you some one on another radio tell you they do not hear you, or are you going by no swing on the meter in the radio?
Could the meter be bad?
Jul 31, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Radio squeals part time and meter only goes up half way when keyed up
you have a Microphone problem.. change your Mic. Mine done the same thing when Mic wires shorted together inside of the handpiece. Also, when it doesn't match the Ohm impedence. you can buy a replacement Mic at www.copperelectronics.com or Radio Shack.
Mar 31, 2011 | Radio Communications
Radio worked fine when bought 2 days worth went to key up mike only sound is a sustained whistle sound,took to repair shop had fixed guy said he rebuilt talkback worked again 2 days same result sustained...
Do it have a relay mod for the talkback if so take that thing out. use the normal talkback. We are in TX.. no charge to check out.. I would check to make sure it has just plain normal talkback, and no other mods done first.. any other mods done??
Mar 19, 2011 | Connex Radio Communications
Buick Regal GS 1999 no starts after having washed engine (done before). Engine turns over, fuel pump comes on - pressure OK, no ''check engine light'' noted. Mechanic changed ignition module and Camshaft...
I wash my engine all the time too. The only thing I can think of that you might have done is get a waterproof seal on or near the coil pack wet. If you have a compressor, take out the plugs and blow them dry. The vat thing, I am unfamiliar with, Unless it is the anti theft system, which is a ****** to fix if it goes wrong. I know it kills just about everything, why not the pump? But if your engine turns over, that is not it. Check the oil. Check the stuff that got the wettest. Hope this helps.
Jun 04, 2010 | 1999 Buick Regal
Cobra 18 wx st receives-wont transmit
Take the cover off, flip it over solder side up, check all solder joints for cracks, cold solder joints, check the safety diode where it comes in the radio, before I go further, can you pick up the weather channel?...Does the PA work?...need to check the pre-driver and finals,audio chip, hook up the power meter using a coax three foot jumper from the output from radio to the input of the watt meter, then the antenna, first check the SWR, on the scale on the meter to cal/swr mode,adjust it to spec, then while still keyed down turn the dial to SWR,if it is the safe range your ok,then turn the Dial to 10 or 20 watt scale and key the mic. Does it have any wattage? If not suspect the finals, they are located on the back rail, if it does have RF then its the audio chip, its located on the right side rail facing you,closest to you.remove it and replace it with same ....hope this helps....
May 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Dodge Caravan 2003 airbag and engine light
Sounds like the HVAC control head needs to be recalibrated. The procedure is fairly easy, Heres how its done:
CALIBRATION/DIAGNOSTICS TEST ENTRY
TO INITIATE TESTS:
Set Blower motor ON HIGH
Set Mode position to Panel
Set Temperature to Cold (Both slide pots if equipped)
Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LED's light)
RESULTS:
All LED's will turn on for 5 Seconds
Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing.
Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.
After all tests have passed, Calibration Diagnostics and Cooldown can be run separately.
After that the lights should go out and everything should work properly as long as everything is in proper working order.
Good Luck
Aug 25, 2008 | 2003 Dodge Caravan
Logitech headset
it is due to mic problem
1. mic cable may breaked
sol. check cable
2. other wise ur pc mic supporting software is not properly added
sol. if u r using windows xp, double click the volume icon ( located on ur desktop startmenu bar) click options, properties,
recording, and check the microphone then click ok button
check and select the microphone button and increase the volume and check it
3. check sound functions, some times ur software used in voice cancelation mode change mode.
Dec 31, 2007 | Logitech Precision PC Gaming Open Air...
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Nokia 6255i Logo
337 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
