Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have an phillps tv and the grean lights comes on and then shuts
Off the tv will not power on
  • Z Laws May 11, 2010
    Knowing the age, model number, general condition would help to diagnose.
    Champion:
  • 230 Answers
Common problem on this tv.
Replace capacitors on power supply board( maybe vented).
2200uf 16V ( upgrade to 35V), 220uf 35V (2), and resolder all connections under fly back area.
encompass.com for parts.
Thank you
Posted on Aug 07, 2009
Lighting strike 42 inch phillps tv mill not turn on
I would first look at the power supply board. it might be a removable fuse. unplug the TV first, remove the back of TV check the area to where the power cord comes into the TV. it should be real close to the power supply board.I have had a couple of quick fixes by just replacing the fuse. (that means it did it's job) if that doesn't fix it try to get the part # from the power supply board and check with Shop Jimmy.com for replacement board. (easy fix) take pictures of the back of TV with cover off and of the power supply board before u do anything. Leave the old board in place till the new one comes in. that way you won't forget where the cables went etc. Just be careful cause the dead board can still hold a charge so handle with care.
Sep 21, 2014 | Philips 42PFL5603D 42 in. LCD HDTV
Phillps tv model number 50pl9126d/37 what is the red light mean
It depends on whether you are able to see a clear image or not. check the lamp first if its more than 2 yrs old you may need a new one, last one we checked with the problem you describe had a fan running slow. The fan nearest the lamp needs to run correctly or the tv will shut down. Good luck !
Nov 11, 2011 | Philips 50PL9126D/37B 50" DLP TV
I need the code for a philips tv
1. turn on your Phillps T.V. 2. Press and hold the setup button (underneath the power button) until the red light stays on. Release the button 3. Push the "TV" button on the remote once (red light sohuld go off) Press the on/off button slowly as long as it takes until your T.V. turns off. 5. Push Enter once to save the code.
Jun 24, 2011 | GE JASRM24912 Remote Control
I have a phillps model 32fd9954 flat screen tv . The tv will say on for about 30min then it shuts off and the light gos from green to red and the tv will not stay on at all unless you wait another 30min
your tv has a defect.maybe loose connection on the board.or theres a shorted parts im the main board. you need a qualified technician to fix that problem.
Jul 11, 2010 | Philips Televison & Video
Projection TV Phillps 60PP9202/17F, bought 2004. Was watching and suddenly the picture went out. All connections are good and components work. Can you help?
Hi.
If there is no power at all, then it is either the power cord or power board inside the TV.
If after the fault the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the support number listed on Philips user manual to arrange repair.
If you are a technician I can try locating parts, service manual and giving more directions. Common faults that affect a Philips rear projections are convergence, PSU board, lamp and ballast assembly.
Regards.
May 28, 2010 | Philips 60PP9202 60" Rear Projection...
The grean light comes on, but it won" power up, Also does it have a reset? It's a tomtom 910
There's a reset on the bottom, next to where you plug it in. A small paper clip will fit. Push it in LIGHTLE to reset the unit.
Oct 22, 2009 | Tomtom GO 910 GPS Receiver
Psp 2001 powering on with grean light but black screen.
you bricked your psp when you downloaded your custom firmware. google pandora and look for batterys i cant tell you where exactly because sony has a copyright.
they should have a pandora battery and magic memory stick order the kit they offer and follow the instructions it comes with. that should install your firmware correctly
Jun 30, 2009 | Sony PlayStation Portable (PSP) Console
I have the 55" phillps rear projection tv
Common problem with this model. Goto www.TvRepairKits.com to get their chirping TV repair kit.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
Can't get regular tv sound to come through my philips htz512 surround system
from your main tv what cable uusing rca cables red white form out of tv to in pf phillps player then hit aux in on phillps make sure tv output is on o k thx nick
Oct 06, 2008 | Philips Audio Players & Recorders
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
