Question about Lands Phones
If i transfer an incoming call to a person how do i return the call
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
IN CASE THE PASS-THROUGH ENTITY FILES A 4708 COMPOSITE RETURN VS. AN 1140 PRESERVATION RETURN, CAN THE INDIVIDUAL STILL TAKE ADVANTAGE OF THE SMALL BUSINESS INVESTOR INCOME DEDUCTION?
The entities selection of filing doesn't change up the individual's ability to accept Small Business Investor Earnings deduction. However, please be aware that the deduction may be stated by a person with an IT-1040 and might not be stated around the IT-4708 or IT-1140. As suggested for FAQ #5, a business might not claim the deduction.
Mar 20, 2015 | Individual Computers & Internet
What are the benefits of renting a granny flat?
The benefits are;
Financial benefits with rent, added security and help around the yard, companionship ... if you choose. This is all providing you get the right person(s). There can be some real down sides if you get the wrong person(s) in as well.
Nov 26, 2014 | Exercise & Fitness
Can't transfer calls
Call Transfer is a Class Of Service controlled function. If you can't transfer it's because your phone is in a class of service (or possibly Class Of Restriction) that disallows it. Note that transferring an incoming call to an outgoing line is frequently barred on some corporate phone systems to prevent toll fraud or abuse. Check with your phone system support person.
Dec 31, 2013 | Mitel Superset 4025 Corded Phone...
I want to file tax returns online in India, Please give me the webpage url.
There are several online website which offer you to file tax returns online in India. Here i have share a web page from where you can file your tax return online. Link is mention below
http://www.taxmann.com/bookstore/tax-compliance-cd/e-filing-of-income-tax-returns-with-tax-computation.aspx
Oct 23, 2013 | Cengage Wests Federal Taxation Research...
How do I send a call to internal voice mail?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Jun 29, 2010 | NorStar M7324 Telephone
How to transfer a call on Nortel Networks M3904
Use the Transfer feature to redirect a call to the appropriate person.
To use the Transfer feature to direct a call to a third party:
To return to the original call, if the transfer is incomplete:
1. Press the Transfer soft key. The other
party is on hold and a dial tone sounds.
The LCD indicator light flashes steadily.
2. Dial the DN to which the call is to be
transferred or use Personal Directory,
Redial List
, or Callers List to select a
number to dial.
3. When that number rings or a person
answers, press the Transfer soft key to
connect the calling party.
If the person called is not available,
press the line (DN) key (next to the LCD
indicator) to reconnect to the original
call.
Jun 23, 2009 | Nortel 2002 IP Phone
How to forward incoming calls
There is a feature that most dealers do not activate called "Voice Mail Transfer" which transfers an incoming call to a person's (or department's) voice mail box. Forwarding calls to someone's mailbox is not possible without special programming by a certified dealer.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Oct 08, 2008 | Panasonic KX-T7633 Corded Phone
Transfering calls
It sounds like your dealer didn't properly set up incoming call distribution groups. They probably just gave you the "default" settings and left you a manual, took the check and said, "Good bye, and good luck!"
I think you mean transfer instead of forward. Your incoming calls should go through an Incoming Call Group - even if you're the only person in the group. Then you can handle the calls as they come in, transfer them out, and if you run out of buttons the system can even queue the calls up until you can get to them.
Jul 09, 2008 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
