My nextbook sync messages no messages will download,notifications sync messages for this label to enable notifications
Primary not synced,social not synced and so on.
  • 473 Answers
SOURCE: Tungsten E - HotSync with Outlook 2003
Don't skip the initial HotSync for secondary computer! Alright, I figured this one out on my own and figured I'd post what I'd learned so that others don't have to endure the teeth mashing, hair pulling, snarling frustration. (self induced as it may be) My experiences have taught me to not always trust a cookie cutter installation wizard...especially for custom app installations (ie: primary = home, secondary=work, total sync, no priority). So, I did not perform the initial sync during installation of the palm software fearing that the new installation would NOT recognize that the work computer was a secondary machine and resultantly wipe out the old palm data from the primary machine. Turns out, as I saw in many other unrelated posts, that it's difficult (if not impossible) to specify conduit direction to outlook 2003 outside of the initial sync (this prompted me to specifically look for conduit direction during install). So, this wizard is one I should have trusted...by mistake...because of weak program design. By the way...once I specified sync with outlook during the initial sync, EVERYTHING works fine despite not having installed the two "imperative" conduit updates (they were uninstalled after several previous failed attempts at this). Hope this helps
Posted on Sep 12, 2005
SOURCE: Samsung G600 Sync Problem
Hi, i downloaded the new version and still have the same problem. It starts to Sync then says Download Failed and reboots my phone. AARRRGGGHH. Could it be that i have Outlook 2007?
Thanks in advance
Posted on Jul 11, 2008
SOURCE: Easy Sync Pro not able to connect to my HTC touch
I had exactly the same problem. I changed location from Easysync on my HTC P3300 from memorycard to internal memory. It worked!!
Using easysync 4.26
Lotus Notes 8.0.2
Active Sync 4.5
Posted on Oct 31, 2008
myrlex
  • 674 Answers
SOURCE: How do I delete all of my Facebook notifications
just select all then delete it, if you want to stop the notification is you need to turn off the subcription. or unsubcrib....
Posted on Sep 09, 2009
SOURCE: Downloaded the sync app to my pc but it won't install.
This seems to be a problem on PCs using Windows 7.
Solution:
1) Click on your Start Menu
2) Select Computer
3) Open Local Disk C.
4) Open Program Files
5) Open Bushnell
6) Open Neo Sync
7) Open Native
8) Delete IGolf.lck
9) Close out of everything, restart your PC, and attempt to launch the Sync Application again when your computer has started back up.
If the above fails to solve the problem, you need to install a new USB driver. Contact iGolf at 858-300-5513 and they will email you the PL2303 Prolific Driver.
Posted on Dec 29, 2009
How do you enable the HDMI feature on nextbook Ares 10A android tablet
By default it is enabled already. If you are trying to connect your nextbook to a TV, try this: To link to the television, simply plug the HDMI cable into the tablet and then into the TV's HDMI port. Following the connection, a HDMI notification pop-up will show on the Nextbook's screen. Select it and choose to mirror content displayed on the Nextbook screen. Next, make sure the TV is set to HDMI input, and what's on the tablet should be mirrored on the television.
Feb 07, 2017 | Nextbook Tablets & eReaders
I can not get my 2014 Ford Focus Titanium to sync driving directions from www.mapquest.com
Here is what Ford says to do. You might want to check to make sure your account, phone and vehicle information is correct. If this does not work, then recommend contacting Ford customer service for additional assistance. Google maps is no longer available for Ford vehicles.
Here are MapQuest instructions:
How Can I Send Directions to My Ford's SYNC Navigation System?
Keep your eyes on the road and connected to the world when you send your destination using MapQuest to your Ford Sync system. You must have an active Sync subscription and register your account on the Sync Owner Site to use this feature.
  1. Map your destination*
  2. Select Send, located in the upper right-hand corner of the map
  3. From the drop down menu, click on Car
  4. Select Sync
  5. Enter your Sync Mobile Number and enter your destination name
  6. Click Send
  7. After receiving notification that the location was successfully sent, press the Voice button on your steering wheel and say "Services"
  8. Say "Yes" when Sync asks if you'd like directions to destination you selected online
  9. Once the route download is complete, the SYNC voice will provide the turn-by-turn instructions to your destination
Please Note: The Send to Car option is only visible after you have created your route. Only voice navigation will be enabled when sending route information to your Ford Sync system.
May 13, 2015 | 2014 Ford Focus - Titanium, sedan -...
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
I need a new password to my nextbook because i cant get in my tablet i know my uesname pls help me my number is 6785549827 i need my password.ps think you i need your help?
If you synced your tablet with your computer you can restore the device with the computer you last synced with. it allows you to reset the password and re sync your data or restore the back-up. Or you can do a master reset by holding the power button and down volume until the menu appears then choose restore factory reset, you will loose all apps that you have downloaded. remember to remove the SD card before you do the reset.
Apr 29, 2014 | Nextbook NEXT2 Touch Screen Android Tablet
I am using samsung s duos.Amdroid version 4.0.4.Previously I used to receive gmail notification when the phone was connected with internet but suddenly stopped getting gmail notification.I want to enable...
Try these solutions:
1. Go to settings > accounts > Google > **your email**@gmail.com > Enable Gmail sync
2. Settings > Mobile Data > Gmail > Restrict access disabled
3. Settings > Mobile Data > (menu button) > Enable Sync
4. Settings > Applications > (scroll right to all) > Gmail > Show Notifications enabled
5. Gmail > (menu button) > Settings > **your email**@gmail.com > Enable Notifications and enable Sync gmail.
*Note that I'm using a dutch language on my phone so the terms I used are guessed translations, actual buttons might have a somewhat different text on your phone.
Mar 18, 2014 | Samsung GT-S7562L Galaxy S Duos With Dual...
Message keeps popping up....
Frequently, this happens do to a problem with your contacts or calender. It's a problem with syncing those items with your Google account or PC. If the problem is with one of these, you should try to manually synch the calender and contacts. (Go to Settings > Accounts & Sync > (Go to Gmail account). You'll see the option to sync the Calender, Contacts and Gmail. Select each one to manually attempt to sync the files. Determine which item is providing the error; you will need to clear the data from the problem application. (Note: back up your contacts first. Use the People > Menu > Import/Export > Export to SD card option if you can.)
Next un-check the sync option for the problem app (calender or contacts) under the Google Account > Accounts. Then go to Settings > Apps > Manage Apps > All and clear the data and cache for the problem app. (The contacts may be under the Running list.) Then re-enable the sync feature. If the calender is causing the error, you may need to erase and re-create your recurring item.
For some scrolling down to the Google Frameworks service in the Manage App > Downloads (or Running) menu then clearing that data. Then chose the "force stop" works to fix the problem. (However, this can put your cell phone into a factory reset state and may cause other problems.)
You will need to turn the cell phone off and back on before re-enabling the sync.
I hope this helps.
Jan 09, 2014 | Samsung Galaxy GT-S5570
How can i push on emails on my 3G iphone/
Getting Started
1 Tap on the Settings app icon on the home page 2. Scroll down and open Mail Contacts Calendars
3 Tap Add Account
4 Select Microsoft Exchange
5 In the Email field, enter your Gmail address Leave the Domain field blank Enter your Google s Username and Password Once done tap Save You might see the Unable to verify certificate error message Select ccept
6 A new Server input field will now appear Enter m.google.com Tap Next to continue
7 Select the Google services that you want to sync. For me, I activated all the available synchronization services. Tap Done google sync enable Your Google sync Push notification services is now set up To activate the push notification you need to turn the Push feature on in the iPhone Settings section.At the Mail Contacts, Calendar section tap Fetch New Data Make sure that the Push is turned to ON Done Few things to note 1 Google sync requires you to be constantly connected to the Web You have to keep your 3G or WIFI connection Always Of for the best result 2 The push notification can be very draining on your battery life If you value your battery life much more than the push technology turn the Push feature OFF for optimal performance Push email support is one of the iPhone 3G s most anticipated features for road warriors but it doesn't work with just any email account Find out how to get hooked up The iPhone 2.0 software available for the iPhone 3G iPhone and iPod touch can t automatically turn any email account into push email It can only instantly send new messages to your phone if your email service supports push email The new iPhone 2.0 software supports push email in conjunction with Microsoft Exchange servers and Apple s Mobile Me service (the replacement for Apple s Mac Apple has labelled Mobile Me Exchange for the rest of us and it can push email to devices running iPhone 2.0 plus keep the device in sync with Microsoft Outlook on a PC or Mail Address Book and i Cal on a Mac he new iPhone s main settings menu now features a new icon Fetch New Data which lets you enable push email You can also schedule the phone to automatically check non-push email services every 15 30 or 60 minutes, or else only manually Which email works with push Push support from other services depends on the provider. The original iPhone supported push email with Yahoo by routing email through i map.apple mail yahoo.com but the service was flaky. This is still the default Yahoo email wizard configuration under iPhone 2.0 but if it refuses to work you can still go into Other and manually set up POP3 Yahoo access Gmail does not support push email only I MAP or POP3 What if I m using G mail or my email from an ISP like iiNet Of course the workaround is to forward your existing email address such as a G mail account, to your Mac account You could even create server side filters on G mail to only forward emails from certain senders to your Mac address to ensure you re not bombarded with push email spam You can also configure Mobile Me to automatically check external POP3 email accounts but this won t get emails from a G mail account to your phone as quickly as it would if your G mail account was automatically forwarding them Push email uses more data The iPhone 2.0 mail client only downloads email headers from I MAP and POP3 servers, in order to save bandwidth When accessing push email services the phone automatically downloads the body of the email and small attachments meaning you need a generous monthly data allowance The iPhone disables its wifi adaptor when sleeping switching over to the mobile data network. This means most of your push email will come down over the mobile data network while the phone is at rest, even when you're within range of a wifi network
Dec 13, 2011 | Apple iPhone 3G
Hi i can seem to sync all my contacts on my mac to my samsung galaxy s can you please help me pls
You can sync your contacts between your Samsung Galaxy S Phone (Or any Android) and a Mac very Easily by synching your address book contacts with the google account linked to your Samsung Galaxy S.
Step 1:
Open Address Book on your Macintosh
Step 2:
Click on Adresss Book -> Preferences
Step 3: Click on the Accounts tab
Step 4: Click to Check the 3rd option labeled "Synchronize with Google"
Step 5: Enter the Gmail (Google) ID and Password that you used when you set up your Samsung Galaxy S phone. and enable synching your contacts with your google account. Your contacts shoud now sync with your google account and automatically download onto your phone.
Step 6: On your Phone make sure The Sync option is enabled (Auto Sync) by going to Settings -> Accounts & Sync and make sure "Auto-Sync" is checked.
Mar 02, 2011 | Samsung Galaxy S GTI9000 Smartphone
Samsung G-600. Got the same problem and used the suggested solution and it worked. Thanks
Oct 23, 2007 | Nokia 1100
Sep 12, 2005 | Palm Tungsten E Handheld
 Grubhead
Grubhead
