A/C.SPLIT UNIT PRE-DEF RED LIGHT FLASHING.INDOO UNIT ALSO NOT WORKING
MODEL NO,ASH-24 QUEEN A/C.SPLIT UNIT
  • 334 Answers
SOURCE: All lights are flashing including Pre Def, Timer,
Not sure the make and model of your equipment you have there but sounds to me like your control board is trying to tell you it is bad.
Posted on Jun 12, 2009
  • 1238 Answers
SOURCE: i have samsung split type room air conditioner,
http://aircon.ru/pbc_download/files/f1215245089.pdf
check out this web site as it has your items manual. It may help you trouble shoot what's going on. There is a trouble shooting section.
Hope this helps.
Posted on Feb 03, 2010
  • 36 Answers
SOURCE: ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
Posted on May 27, 2010
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
SOURCE: Mitsubishi split-type air conditioner model
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
Posted on Mar 11, 2011
Toshiba AC Pre-Def orange light is flashing as well as operation green light is flashing. What could the possible fault be.
Please re post and include the model number and place the question under the correct heading for our experts to pick up for you. This is laptops.
Dec 24, 2016 | Toshiba Computers & Internet
Goodman minisplit flashes on pre. Def. Wont start
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Apr 07, 2015 | Goodman Heating & Cooling
How to reset pre-def red light blinking on teco aircon unit
Air Conditioning Tamarac
Jun 10, 2013 | Heating & Cooling
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have a constant flashing red light and the unit has ceased to work. What can I do?
the red light flashing relates to the problem with the power supply board. If the model is pre 2003xxxx serial number wise then this has a known power supply issue. contact point of sale or b and w service and they should arrange to repair. There are other noise issues with older models which they should also check once they have got the unit working.
Mar 20, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
Ice fallingfrom split ac
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
Gold Star mini split heat pump 24,000 btu. Changed indooe as we as outdoor boards and still goes in cooling mode only. Reset button on outdoor board calls in heat but not by inside hand set. Len Cabana...
On a heat pump the difference from heat to cool is the reversing valve.
In cooling or heating the Y1 terminal will always be energized, this is the contactor.
Depending on brand the reversing valve will either be energized in Heat or Cool. At the outdoor unit check to see if the reversing valve is getting 24 volts in cool, if not check to see if it is getting 24 volts in heating. The easiest way to check if the reversing valve is shifting, is to feel the big copper tube, (it is not the suction line on a heat pump) this is a refrigerant vapor line. It will be cold in cooling and hot in heating.
Check your thermostat installation instructions and heat pump installation instructions to determine the proper terminal designations for your heat pump and thermostat. There are some brands out there that use the B terminal as common to the 24 volt circuit, so you have to check the wiring and make sure this is not common.
If it is energized in Cool then the Y1 and O terminal will be energized. You will have 24 volts from common usually the C terminal to Y1 and O.
If it’s energized in Heat then the Y1 and B terminal should be energized. You will have 24 volts from common usually the C terminal to Y1 and B.
If you get heat when you’re calling for cooling or vice versa then switch the wire between the B and O terminals.
Feb 01, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
