Question about NexxTech 175W Power Inverter
I HAVE USED THE NEXXTECH 175 WATT POWER INVERTER
I HAVE USED THE NEXXTECH 175 WATT POWER INVERTER FOR A NEBULIZER MACHINE WHICH I NEED TO USE IN MY CAR FOR A BREATHING PROBLEM I HAVE, I HAVE USED THIS IN THE PAST AND IT WORKED FINE FOR ALMOST 2 YRS, THEN IT DIED, SO I BOUGHT A NEW ONE THROUGH SOMEONE ON EBAY AND THE LIGHT GOES ON AND IT JUST BEEPS, BUT DOES NOT POWER UP MY NEBULIZER
    Guru:
  • 290 Answers
Have you charged it,and check if the battery is still ion good condition
Posted on Feb 26, 2010
I bought a Nexxtech 175 watt inverter to power my laptop. It worked fine in my truck in the store parking lot but won't work in my tractor where I really need it. It works from the power point or the...
It could be any of a number of things, but the first 2 guesses I am going to make are:
1) The contacts in the cigarette lighter jack in the tractor are corroded; or
2) the wires that power the cigarette lighter jack in the tractor are too small of a gauge to provide enough current flow without a voltage drop. This one can be tested by popping the cigarette lighter jack out of the dashboard while still wired (carefully, you don't want to cause a short-circuit), and then plugging in the inverter and measuring the voltage with a multimeter going INTO the lighter jack. It should be at least 11.5, preferably 12, Volts. Test both before and after the inverter is plugged in. If the after reading drops too much, then you know you need a bigger gauge wire feeding the lighter jack.
May 06, 2014 | NexxTech 175W Power Inverter
175 watt 350 peak inverter 12v dc to 110 ac need a fuse but don't know what size to use. old fuse is missing.
Hi
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Regards
Jan 30, 2011 | NexxTech 175W Power Inverter
I have a problem with my dell studio 1535 lcd.i guess the problem is with the inverter.how t check whether the inverter is working by using an ammeter
1 check if the battery is still good by switching the meter to DC and test it if it is still reading the correct voltage.if not the batteries may be bad
2. switch it to AC and check the out put if it is supplying a voltage output.if not the transistors may be bad
Mar 04, 2010 | Dell Studio 15, Studio 17 175-Watt Power...
Can my toshiba laptop run on a 175watt power inverter in truck? the toshiba is satallite l305-s5974, and inverter is a roadpro 175watt/140watt constant with overload/overheat protection built in? the power...
you dont need to buy anything from radio shack, the inverter that you have will be just fine. i have used smaller and im sure cheaper inverters with no problem. i keep my company laptop constantly plugged in and charging all day everyday running service calls.
Dec 17, 2009 | Toshiba Satellite L305D-S5904 Laptop
Fuse missing
I would start with a 1.5 AMP fuse (175 watts / 12 VDC = 1.6 amp)
Make sure the fuse is rated for at least 120 VAC. Hope this helps!..Gary
Mar 10, 2009 | Dell 175 Watt Power Inverter Car Adapter...
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
Power inverter pc 500 once u put power to it the red light comes on and beeps but no a/c power
Hi there
Not a great solution but makes sense.
the ac adaptor for your alienware probably says input 240V ac 1.5Amps whilst the inverter can output 175W= 240V ac at 0.73Amps.
I am surprised it actually worked, i had to buy a 300W inverter to run my laptop. would suggest you do the same.
inverter is probably toast now anyway.
Feb 25, 2009 | Alienware PC Systems 175 Watt Power...
Ruining lap tops
175 W inverter is not enough power for your computer and most of the cheap inverters do not put out a true sine wave. Buy one rated at least at 400w. Then it will output continuously at 300w. That should be sufficient for your computer. Your 175 w inverter is overtaxed then the voltage drops increasing amperage and burning things out.
Jan 26, 2009 | NexxTech 175W Power Inverter
NexxTech 175W Power Inverter Logo
390 people viewed this question
Top NexxTech Electronics - Others Experts
Are you a NexxTech Electronics - Other Expert? Answer questions, earn points and help others
