Question about Garden
Tractor won't start has fuel changed filter still nothing
  • 109 Answers
SOURCE: model#917.276020 25hp 48
On the bottom of the carb., there is an anti-after fire solenoid, take it off and make sure that it is working with the key switch, it should retract when the key is turned on and go back out when the key is turned off, if it doesn't check the red wire to make sure it is still connected
Posted on Apr 24, 2009
wadembly
  • 513 Answers
SOURCE: Hard start or won't start
the float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ wadembly@aol.com
Posted on Jun 28, 2009
SOURCE: peugeot 306 won`t start off ignition
started car had only just gone around the corner and heard a burst sound then hissing thought it might of been radiator hose. stopped car checked main radiator hoses took radiator cap of released pressure ,but hissing continued sounded like it was coming from mid part of engine any ideas what it could be..
Posted on Nov 09, 2009
barterjoe
  • 344 Answers
SOURCE: john deere tractor 1070
The lookup at:
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
for the model 1070 harvester shows it is a 3 cylinder unit.
What I might recommend is pull off the valve cover and make sure the intake valve is moving up and down as the engine is cranking. (dont get cut up)
It sounds like a pushrod may have fallen out.
good luck.
Joe
Posted on Feb 11, 2011
oberkiuler
  • 51 Answers
SOURCE: my ford expedition won't start i change the fuel
If it a diesel then you must be aware that when changing a filter and pump they must be full of fuel, otherwise it won't **** the fuel into the engine.
Posted on Jul 11, 2011
Replaced fuel tank now tractor won't start. It cranks good but just won;t start.
Probably have air in the fuel line not letting any fuel getting past, it will collect at the highest point..
If you have inline filter replace with a drill pump to suck fuel along pipe, or to force fuel back to tank, you will also need to fill the part that is post filter point
Sep 29, 2015 | Cars & Trucks
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman silver won't start
ground the spark plug to the engine block it should spark. sounds like you need to check the valves and push rods
Jul 04, 2017 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
I HAVE CHANGED THE FUEL LINE AND THE FUEL FILTER ON MY TRACTOR, AND THE TRACTOR WILL TURN OVER, RUN FOR A LITTLE WHILE AND THEN STALL, THE FUEL STOPS ENTERING THE FUEL FILTER AND I CANT GET IT TO TURN OVER...
Fuel pump will quit working properly like that we had a car back in the 80s we carried a gallon of water to poor on the fuel line and it would start working again I hope this helps Merry Christmas
Dec 09, 2017 | Craftsman 175 hp 42" Lawn Tractor (CA) ()
Skid steerer won 't start
You need to remove the fuel filters and fill them with fuel, and them if you engine is equipped with a primer,,,,prime the fuel system.
Simply filling the fuel after a run out will never start it. The system has air in it that needs to be primed out.
Aug 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jun 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
