Question about The Computers & Internet
I own a Citroen C5 3L diesel 2010. I want to know why the back of the car does not rise back to normal position after lowering the suspension.
Bill
dgjtex
  • 405 Answers
SOURCE: AIR SUSPENSION PROBLEMS FOR 2000 LINCOLN TOWNCAR CARTIER
I have serviced these in the past and it will probably be a combination of things. I just a few weeks ago fixed a 1999 with the same problems. Generally from past repairs, the electric pump has been working overtime to compensate for leaking rear air shocks. The best solution is to replace them both, not a cheap repair, the pump around 275.00 and each shock arount 275.00.
Just with every thing over time things fail, the rear shocks develop leaks over time/weather cracks, they are easy to check, soapy water will identify this as the problem. If you can get under it enough to spray around the bottom of the shocks when they are inflated. These systems are computer controlled and if you have the proper scanner you can check the system out for eletrical problems easily. My past experiences with these suspensions as almost always the shocks and pump.
Posted on Dec 14, 2008
  • 74 Answers
SOURCE: suspension not rising
is the switch in the trunk turned on?
Posted on May 31, 2009
  • 81 Answers
SOURCE: citroen BX 19 TRS REAR SUSPENSION PROBLEMS, WHICH
Ok, two possibles here. One is that your rear spheres have lost their gas. (Most likely, especially given age of car). Easy enough fix, and the spheres can be got from the likes of allmake for about 30 quid each. Other possibility depends on a couple of factors: if the car doesnt rise at all, after starting or changing the ride height, your main reservoir is probably at fault. If it does rise, but only at the front, then there is a fairly common issue within the levelling system. i cant remember exactly, but there is a ring that needs replacing. Give a citroen dealer a ring...they may even explain it over the phone...
Posted on Jul 12, 2009
  • 6 Answers
SOURCE: Air suspension
YOU NEED TO CHECK YOUR AIR SUSPENSION! If the truck is under warranty, take it to your Ford Dealer to adress the issue.
Posted on Dec 15, 2009
SOURCE: Air Rise Suspension/computer module
i went to auto zone and bought coil springs for my 93 town car went home jacked it up disconnected the air bags pulled them out put springs in let it down and was driving in less than 45 minutes. at a cost less than $200.
Posted on Feb 23, 2010
2010 Chevy cruze 2.0 diesel heavy notchy steering problem
u joints in lower part of column probably have rusted and need replaced
Nov 01, 2016 | 2010 Chevrolet Cruze 2.0
Hi my c2 bonnet cable has snapped.
Cut back the sheath around the inner release cable inside the car, and using a good pair of locking pliers (Vise Grips) pull the exposed cable.
Oct 13, 2016 | Citroen Cars & Trucks
Citroen fault codes p1352
fuel pump has nothing to do with suspension ....i have same prob ..engine runs ok and can drive/reverse ok but car will not rise so topped up LDS fluide reservoir ,checked all fuses ok ,no visible leaks so reckon hydraulic pump worn out...will look on ebay for one
Dec 31, 2013 | Cars & Trucks
Creaking noise when pulling off mainly on hill starts,lasts for a few seconds
could be suspension noise either the rubbers on the top of the suspension or the anti roll bar link rubbers. both fixed easy with some wd40... unless they split. then they will need replace them.
Dec 08, 2013 | 2010 Citroen DS3 THP
Suspension diagram for a 2001 citroen saxo furio 1.4
If you call your local dealer where the car is made and talk with the parts department they can tell you what stock is. Make sure you give them your vin. # when. You call
Jan 11, 2012 | Cars & Trucks
Is there a way to check if air shocks are operating correctley before I purchase mark 8
you mean air suspension. yes, there is a switch in the trunk i think on left side. turn it off , then open hood and on the air pump for suspension there is a regular air valve like on tires. Release the air from system, car will lower down.. then turn switch in trunk back on and start engine so the pump wont kill battery , and watch the car rise again to normal height.
Nov 08, 2009 | 1996 Lincoln Mark VIII
Citroen BX 19 TRS REAR SUSPENSION PROBLEMS, WHICH
Jul 11, 2009 | 1989 Peugeot 405
Suspension not rising
May 30, 2009 | 1992 Ford Crown Victoria
Computers & Internet Logo
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
