Question about The Office Equipment & Supplies
LSU error and how to reset the problem - The Office Equipment & Supplies
How to troubledhoot the LSU error on samsumg
repalce laser unit or check menu # 1931 lsu mirro test
Aug 03, 2010 | Samsung SCX 4521F All-In-One Laser Printer
What is mean by LSU error of samsung all in one printer ? how i can overcome this problem ? Because of this LSU error i m not able to take printout ? plz help me. my printer model is SAMSUNG SCX-4521F
LSU = laser scanning unit. I have a similar problem and i solved it by reseting my printers memory. You must enter tech mode. --> Data setup --> Clear all mem
Jul 29, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Engine LSU error printer model samsung ML2150
how can over come from LSU error problem in samsung all in one machines
Jan 21, 2010 | Samsung ML-2150 Laser Printer
No reset will work, it is detecting the Laser Scanner Unit is not operating correctly and it is a replacement unit (LSU).. the lsu is a high speed motor with a many sided mirror attached spinning at very high speed (you can hear the whine in lasers of the spin), the motors wear out and cant spin fast enough yo spread the light and need to be replaced... then your error will clear
Nov 07, 2009 | Office Equipment & Supplies
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
Jul 28, 2009 | Samsung SCX-4100 All-In-One Laser Printer
LSU error message
That is the Laser unit. Not good. There may be a service reset process but you'll have to send or call it in.
Mar 18, 2009 | Xerox Phaser 3200MFP/N Laser Printer
Error LSU
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Jul 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
27 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
