Question about Quad Lands Phones
My BT Synergy 6500 quad phones show the Y symbol & 'Searching' all the time. I am unable to de-register.
If I press de-register, it says 'Unavailable'. If I press register; then message comes on - 'choose Base' & the Base 1 which is the main base unit shows 'In use' always. So unable to register the base unit to the 1st handset- keeps saying 'Registration Unsuccessful' always. Phone line is fine since it rings but I can not answer / make calls. The phones worked fine. Just changed new batteries due to crackling noise during calls.So tried corded phone on main phoneline , unplugged BT6500 since new batteries were charging. After that when I removed the corded phone & plugged the BT 6500 main base unit the phone is not working, not de-registering or registering. Really frustrating. HELP !
5 Suggested Answers
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
  • 205 Answers
SOURCE: phone cannot find base
complite opening phone re connection remove safty try it
Posted on Jul 09, 2009
  • 7 Answers
SOURCE: phone not working
call your carrier
Posted on Oct 05, 2009
How do I ring no 2 handset
you don't it has the same number as # 1 does
Mar 26, 2016 | BT Synergy 6500 Cordless Phone - DECT -...
I have changed the batteries on a Synergy 6500 handset but it does not charge and the display is blank. What could be the problem?
No actual idea, but check user manual, go to BT website and check there (esp FAQs). Do BT have a customer helpline?
May 16, 2015 | BT Synergy 6500 Cordless Phone - DECT -...
Ho w do I deal with power cut and flat battery?
As batteries go thru many charge and recharge cycles, they lose their ability to retain full charges. Time to buy a new battery.
Dec 08, 2014 | BT Synergy 6500 Cordless Phone - DECT -...
Bt 6500 instructions
www.ukcordless.co.uk/.../BT%20Synergy%206500%20User%20Guide.p.
See if the above guide tell you how.
Jun 01, 2014 | BT Synergy 6500 Trio Dect Cordless Phone -...
Additional handset on BT Synergy 6500 phone is stuck on 'Test Mode'
is possble to use 8 bt 6500 hand phones via 2 base unit on the one bt line
Feb 28, 2012 | GE 25942GE2 Cordless Phone System
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
Set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Sep 26, 2008 | British Telecom Synergy 2110 Cordless...
Bt freestyle 210
I have found a free link to the user guide for you on the BT site, it is a very comprehensive guide and there is a BT helpline number if you are still having problems
http://www.shop.bt.com/content/uni2/documentation/4j8p/028609.pdf
Dec 21, 2007 | British Telecom Synergy 2110 Cordless...
Lands Phones Logo
41 people viewed this question
Top Quad Lands Phones Experts
David Burbee
David Burbee
Are you a Quad Lands Phone Expert? Answer questions, earn points and help others
