Question about Miele Refrigerators
F1413SF Miele 18'' All Freezer, Pr 10/07/2015 Fitter
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
Model cs1011G will not stay burning - gas peters out
check for a faulty gas regulator or low gas pressures
best have this done by an accredited gas fitter as they can diagnose the problem properly.
Aug 14, 2015 | Miele Cooktops
Can you help me solve the problem with F623Ui freezer? It doesn't freeze and the temperature is -9,5 C
Hi Anonymous!
Here is an operating manual for your freezer. Troubleshooting start on page 25.
Good Luck,
JP
Miele 623 Ui Operating And Installation Manual
Jul 06, 2015 | Miele Refrigerators
I have got miele fridge freezer but the fridge keep freezing what can I do
Usually a faulty temp sensor on the fridge evaporator, not an easy repair for most, I would personally recommend Miele's fix priced repairs
Service Repair Miele Support Miele UK
Sep 19, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
The thermostat has risen to 30 degrees although we
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 23, 2010 | Miele 3.80 cu. ft. / 108 liter Upright...
Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
Jan 10, 2010 | Miele KF7642S Bottom Freezer Refrigerator
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
MIELE KFN8762SDED (SS/fridge/freezer)
No problem just use the + and - buttons when you have chosen the temp. you want just let go and that is the temp the fridge or freezer will set at.
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Miele refrigerator Model KFN 8993 SDE (I believe)
Similar to this, although I also had a build up of frost in the freezer. Advice from Miele:
"You have a fault on freezer evaporator sensor and will need an engineer to call and repair please contact our office o 01235554466 to arrange a service visit."
Rather than this, which i assumed would be expensive but didn't bother calling, I defrosted the fridge/freezer overnight and turned it back on in morning. Freezer cooled down to -18 in a few hrs and since then all is working fine - it's been a couple of weeks or so now.
Oct 18, 2007 | Refrigerators
Refrigerators Logo
Top Miele Refrigerators Experts
mike cooper
Daniel Phillips
Daniel Phillips
freddyfox
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
