Question about Vax Vacuums
Need to open dirty water tank vax rapide ultra to remove dog hair.
reddevil6
  • 1673 Answers
SOURCE: Vax problem
Could be a bad pump.
Posted on Feb 22, 2008
SOURCE: vax rapide not realising water
I have just managed to fix the problem i had with my vax rapide not releasing water. I also tried tilting it and that did not work. I unscrewed the brush from the base of the carpet washer and there is a black plastic strip with holes in where the water comes out of and onto the carpet. I used a needle to unblock these tiny holes which had become blocked after the last use. I now have it working again.
Posted on Mar 08, 2009
SOURCE: water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Posted on Jun 14, 2009
SOURCE: My Vax rapide is not sucking up water?
I had the same problem. Then I took off the brushbar (it's underneath at the front). It just pops off. Then it worked fine. I guess you only need it for long carpets.
Posted on Aug 29, 2009
VacuumRepair
  • 438 Answers
SOURCE: My Hoover Steam Vac Spin Scrub aw/ Clean Surge
Greetings,
A few more things that you can try on your SteamVac. First remove the dirty water solution tank from the machine completely. You should see where the solution tank was just sitting, a plastic casing with a whole in it. This is actually where the suction from the motor goes into. Turn the machine on and feel the hole there for any suction coming out. Did you feel suction coming from the hole? If yes, then your issue is going to be something with the dirty solution tank, because without the tank it's sucking fine. If you didn't feel any suction from this hole, it may indicate that there is something more serious that needs to be taken care of.
One other place you may look on your machine (as long as the upholstery hose for stairs and furniture is already attached to the machine, and you don't have to hook anything up to the dirty water tank to use the attachments) while the dirty solution tank is out of it, is where the attachment hose makes connection with the vacuum. If you recline the handle down while you have the dirty water tank out, look in the back of the handle housing for a hose that enters the housing 3/4 down the housing. Now follow the hose on the inside of the handle not the outside, follow it up to the point where it goes into the neck, near where the suction hole is. Right at the end of the hose, right before the hose cuff, is this ripped, or damaged here?
Please feel free to request a clarification to this repair if you still need addtional help. If you can leave me the model number exactly that would help me help you, lol. I hope that this was helpful to you. If this was helpful to you, may you please click the helpful Thumbs Up Icon in the lower right hand corner of this repair?
Thank you so much,
Chris J.
Posted on Mar 21, 2010
Rapide XL. Why isn't it sucking up the dirty water?
you need to set it lower for water
Aug 10, 2015 | Vax Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
How can I clean or open the bissell quicksteamer dirty tank
Hi Deni! The collection tank can not be opened for cleaning. You may want to fill the tank with some hot tap water and let it sit for about 30 miutes.
Here's a link to our website if you decide to order a new tank.
http://www.bissell.com/parts/?id=9143&sc=part&partid=4482&cid=ccsocial
Jan 16, 2013 | Bissell 1770 Quicksteamer II Upright...
Vax rapide ultra not sucking water
Dear Sir:
Retach the nozzle to the cleaner. Cleaned can be blocked most of the time.
Wait for cool down, and try again.1( See the hose defective 2( Test pumpmotor for some wires loose or belt if there are, so you need replace.
God bless you
May 26, 2012 | VAX Appliances Agilty V123 Upright Wet...
Vax rapid ultra brushes not turning
Dear Sir:
1) Test the power cord for defective wires, broker,or loose repair
2) Test the switch for open see the diagram
3) See if there are some open fuse.
4) See if the belt is broken, replace.
5)Test the input voltage motor.
God bless you
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
Greetings,
Thank you so much,
Chris J.
Mar 21, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Bissell 2x wont **** up the dirty water
take the tank off and turn the unit on and see of there is section where the tank would sit. If so then the tank is not seated correctly, if not it is plugged with something.
Jun 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vax problem
Feb 07, 2008 | Vacuums
Vacuums Logo
37 people viewed this question
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
