Question about Sunbeam Heating & Cooling
My sunbeam heating pad is flashing an F I've tried almost everything it seems like and it's still doing the same thing. I even had it unplugged for 4 days and still nothing.
MicrowaveSvc
  • 9098 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
PRELIMINARY REPLY
This is just a preliminary reply. We will need more information to help you.
So you're saying you can set the cooking time but when you press Start it won't start?
If this is the case, you probably have a bad door swithc or door switch mount.
Please reply back with more detail so we can help you.
Posted on Dec 07, 2007
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Posted on Jan 10, 2009
SOURCE: F2 Fault Code On Heating Pad
I am trying something now as I was told F2 requires you to check the blanket for wear and tear and plug it back in. 3 times doing this should be sufficient. If it still reads F2 it's "gone" Ours is new so it shouldn't be "gone" but here's what I found...Where the plug goes into the blanket there are 4 holes for 4 silver pins. I noticed the 3rd pin was a bit lower than the other 3. It will not move up with pliers so don't force it just return it. check there
Posted on Feb 02, 2010
SOURCE: Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Posted on Sep 28, 2010
SOURCE: Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Posted on Feb 28, 2012
Sunbeam heating pad flashing F
Unfortunately I bought this heating pad three months ago and it too has an F in the display which I think means 'failure' but I do not know why. Also this is brand new and has worked fine for three months. Now what?
Does anyone out there have a comment to help me and this original person asking this question?
Jan 04, 2014 | Sunbeam Xpress Heat Heating Pad 2013-912
Get F2 error code on sunbeam heating pad model cat93, contrller sw404
Crimped the ends of the heating pad cord where it attaches to the pad a little then did the plug and unplug three times while holding down the on-off button and that did the trick
Jul 03, 2011 | Sunbeam 805810 HeatSense Heating Pad...
I bought a Sunbeam Heating Pad (Ultraheat) last year which I just took it out of the box last night. It is brand new, not used until last night and it smell like it was burning. I instantly unplugged it....
Sorry to read about your problem, I hope this helps you out.
i think from sitting in the box for a year, the material can smell, form its first time usage.
I suggest you put the pad on or in a baking dish on the stove..plug in and see if the smell burns off. I think it will.
if not return to Sunbeam (800) 435-1250
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Sunbeam 722 Heater
I just moved to New Zealand
It seems like the AC converter may not have the ability to procduce enough current. Check the wattage of the heat pad then see how many watts the converter can produce. (watts = volts x amps). You can buy a good Sunbeam electric blanket in NZ for about $110NZ, a capable AC converter may cost you considably more. Enjoy your stay in NZ!
Jun 19, 2009 | Sunbeam SG7621SP Grill
Jan 10, 2009 | Sunbeam 722 Auto Shut-Off Heating Pad...
New heating pad not working
Apr 26, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Mar 21, 2008 | Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
