Question about Whirlpool Washing Machines
Washing light flashes green and door lock flashes red on Whirlpool frontloader. replaced door lock assembly. this did not fic the problem
Whirlpool WFS1071BD frontloader
Lumpy816
  • 246 Answers
SOURCE: whirlpool duet sport frontloader washer, door wont open, locked up.
Not a problem glad we could help.
Posted on Jul 11, 2008
mumma_1
  • 903 Answers
SOURCE: Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Posted on Oct 23, 2008
SOURCE: 3761/5 whirlpool washing machine door locked flashing won't cycle
need a manual for washing mashine Whirlpool AWO 10561
Posted on Sep 06, 2009
  • 343 Answers
SOURCE: my washing a whirlpool awo 10761 front loader,when
If you can still open the door when it's supposed to be locked it probably means that the interlock on the door catch is faulty.Easier to fix than if the door is locked shut!!...Not a big job but should be done by a qualified tech. See if you can find an independent, self employed tech...Generally cheaper and better than 'Brand Name' servicemen..Good luck..........Nomess
Posted on Apr 18, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a whirlpool WFS1071BD.
Hi and welcome to FixYa, I am Kelly.
This is the WFS1071AW version of the manual and the pump cleaning instructions are the same:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001
And then enter "WFS1071" Instructions for removing the filter are on page 14 of the user manual.
(Wth pictures)
Pump / Filter cleaning POWER OFF UNIT UNPLUGED:
Basically you open the lower panel by pushing down and pulling toward you at the top. Use something like a cake pan for catching water. Grasp the CIRCULAR filter and rotate it COUNTER CLOCKWISE until the water starts draining. WAIT until all the water possible drains. Then unscrew the filter and pull it out. Clean out any debris. Make sure to reach deep into the filter hole and CAREFULLY clean off the sensor if you can reach it and then reinstall the filter by rotating clockwise. Last steps install the lower panel and PLUG IN POWER.
Thanks for choosing FixYa,
Kelly
Posted on Feb 24, 2011
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Aug 25, 2008 | Hotpoint WMA46 Front Load Washer
Whirlpool frontloader 6AWM8143
It's faulty contact the manufacturer or the seller
Feb 02, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal De
