Question about Cell Phones
My charger port on my Intel next book broke. How do I do a quick fix so I can charge it?
maverick218
  • 61 Answers
SOURCE: charger port on LG shine broke.
It could be either your charger is broken or the charging port in the phone is- I would recommend taking it to a store and have them check it out for you.
Posted on Jan 31, 2010
brownline45
  • 310 Answers
SOURCE: the gameboy wont charge
maybe you have to go to an electronic technician to fix your problem.they have the expertise in opening the gameboy and repair the broken charging port.
Posted on Jun 25, 2010
  • 4102 Answers
SOURCE: The charging port came out of the phone when my
Hi, im sorry to say its not something you can do yourself you just wont be able to do it without causing damage to the circuit board by the heat caused from soldering, i mean if your not that bothered about the phone then you could give it a try but im more or less sure you wont manage it.
put it this way the place you need to solder is so small the chance of getting the solder to stick on to a part thats less than half a ml is risky you just wouldnt get the solder to only solder what you need, their is so much stuff around the solder points that you would touch the solder on something else, these parts are fitted by a machine and the machine disipates the heat and this stops the circuit board over heating.
your best option would be take it to a phone shop and let them sort it for you, you wont be able to use the old part as the pieces that broke off wont sit level when you solder it back on and if you did it would only come back off again when you plug the charger in
if your not bothered if it will work or not then by all means have a go but i would put money on it not working, not because you have not got the skill but just because its in such a tight space that human fingers get in the way.
its up to you but i would not risk it i would get a shop to send it off and have a new part fitted.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 29, 2010
  • 3287 Answers
SOURCE: charges at home on a usb port but not in the car
Hi Carl,
You should check your car's fuses to see if the one that supplies power to your USB charger is still good. If you're not sure how to do this, you could try plugging a different device into it and see if it works. If it doesn't - you'll need to inspect the fuse or wiring. (you could also try the charger in a different port or different car to see if the issue is tied to the charger).
If the other device does work, it is possible that the charger has a built in fuse. If the charger is the type that plugs into your cigar lighter, you may find the the tip holds the fuse. The tip may reveal the fuse if unscrewed from the body or may require a screw driver to open the body. Either way, you'll need to ascertain if there is a fuse in it and if so, check its condition.
Sometimes, the charger needs to be aligned a certain way in the cigar lighter / power port (or outlet) due to the way some automakers and device manufacturers design the connections. Repeatedly remove and replace the plug in the lighter / port. Each time, turn the the plug slightly so that it takes 6 to 8 insertions to rotate all the way around in the outlet. This should provide at least one position that allows the plug to make the required contact in the lighter / power port.
Lastly, make sure that there is no foreign object / debris in the outlet, that the the plug fits snugly in the outlet, the the plug's tip has a spring pushing it forward and that the plug is fully inserted into the outlet.
Hopefully, one of these suggestions will get it working. Good luck!
Posted on Mar 22, 2012
  • 58 Answers
SOURCE: the charging port broke of from my htc evo 4g phone.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Sep 10, 2012
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
My charge got broke can i use a regular usb charger
Press "Volume +" together with "Power on", during 8-10 seconds. Choose first line in menu.
Feb 08, 2014 | RCA Ipod Tabletop Charger With Usb Port...
The charging port broke of from my htc evo 4g phone.
First Option:
Second Option:
Sep 10, 2012 | HTC EVO 4G Smartphone
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
My sony erricson K750i wont charge?
try your charger with another phone to be or try your phone with another charger to be sure the charger is good.
If the charger is good, then the next thing to check is your phone's charging port. Some times, the charging port for K750i is usually dirty, have dust, or may be rust and won't contact the charger well because of this, thereby, not making the phone charge.
Get a metal and use it to scratch all the areas of the charging port, then fix in your charger to see if it will charge.
If it still does not charge, then it means, you have to get another charging port.
You also have an option of using a desktop charger to charge your phone.
Good luck.
Apr 20, 2010 | Sony Ericsson K750
Charger port on LG shine broke.
Jan 30, 2010 | LG Shine CU720 Cellular Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
