Question about Home
How do I tighten the toilet seat of a Axa X?Tre CC BTW Toilet Suite Scs WH
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
woobie dog
  • 1273 Answers
SOURCE: Toilet seat connectors mounted on toilet is loose
There should be a way to tighten the bolts without going that far Here's two things:
Look at the lid, with the seat down. The bolts are sometimes covered with a snap-in palstic cap or flap. If so, pry up with a screwdriver. Then use a screwdriver and wrench to tighten.
If the bolts appear to be cast as a part of the hinge assembly, you should be able to reach around the seat to the back side (no pun intended) of the toilet, and tighten with a wrench.
I sometimes use a 'mirror trick' to get a better idea of what's back there. Just use a small mirror and hold it to where you can see the bolt and not on the back.
Hope this gets you going (oops, another unintentional pun).
Best regards, --W/D-- please feel free to rate this solution..thanx!
Posted on Aug 01, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
olddewsons
  • 38 Answers
SOURCE: toilet seat come loose and no obvious way to
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
Posted on Oct 11, 2009
co7196
  • 3433 Answers
SOURCE: I cannot tighten the toilet seat on my kohler 3386
Give Kohler a call AFTER you read the instructions thoroughly. Good Luck, seriously.
Posted on Nov 09, 2009
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do you tighten the posts on a rak toilet
Look where the seat attaches to the toilet bowl. There are 2 nuts underneath.
Those are the nuts you tighten. they will hold the seat firmly.
Aug 19, 2014 | Home
How to tighten an american standard toilet seat
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
Oct 24, 2013 | American Standard Church Seats EL270...
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
Replacement seat....size???
American Standard is the brand, so you've got a start there, but 1.6 is a flush measurement. Look around the inside for a tank for a model number - with AmStan toilets it's usually a four digit number beginning with a 2 or a 4. This will be what you need to get the OEM toilet seat. However, since toilet seats are purely cosmetic (they don't affect the functioning of the toilet), you can literally take a few measurements and find something that simply keeps you off the porcelain. http://www.plumbingsupply.com is a good one for toilet seats, btw.
Aug 21, 2012 | Home
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
I have a toilet which is a one peice. The toilet seat has come loose and the bolts have dropped to the floor. I can not fit the seat back as the pieces that i would use to tighten the seat are on the floor...
In no case would you ever have to pull a toilet to get to seat bolts.My guess is if you take the tank lid off and look inside there youll see the bolts . If not you can buy another toilet seat with new bolts or just get the bolts to fit your seat and tighten it down.Forget about the old bolts unless they become a problem with the flushing of the toilet. Hope this helps
Jun 22, 2010 | Home
My toilet seat is loose but there are no visible external securing parts. Its a Banyo suite with gentle self closing lid mechanism. How can I tighten it up and secure it back in place?
where the hinges sit, use a small screwdriver and prise off the top chrome cover.Under neath are the securing screws for the seat. tighten these carefully until seat is secure, then replace the covers.
May 13, 2010 | Home
Loose Toto toilet seat
Sep 06, 2009 | Home
Home Logo
50 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
