Question about Cell Phones
TO KNOW THE PRIVATE CALL NO ON MY PHONE - Cell Phones
  • 1,555 Answers
There is no way in which you can come to know the private number shown as private number on your clip. I can only tell you what it is. These type of private numbers are shown when they come from a company having 6-7 lines which in turn are connected to internal exchange with 200-500 extensions. Every extn has to dial zero to dial outside line. and once they do so their own extension number is not recorded anywhere in such companies. Somehow if you get that land line number then also it would be of no use to you because you won't be able to find from which extension that call was made.
Posted on Jul 25, 2009
How to set Private Browsing?
The procedure to set private browsing can vary from browser to browser. Also, the term used for private browsing is different for different browsers. To know more about what term a browser uses for its private browsing mode as well as to know how to set private browsing, refer to the following section:
For Internet Explorer
Known as "InPrivate Browsing"
Refer to:
http://windows.microsoft.com/en-IN/internet-explorer/products/ie-9/features/in-private
For Google Chrome
Known as "Incognito mode"
Refer to:
https://support.google.com/chrome/answer/95464?hl=en
For Mozilla Firefox
Known as "Private Browsing"
Refer to:
https://support.mozilla.org/en-US/kb/private-browsing-browse-web-without-saving-info
For Apple Safari
Known as "Private"
Refer to "To visit sites without making history, turn Private on or off in Safari section":
http://support.apple.com/kb/HT1677?utm_source=Agillic%20Dialogue
For Opera
Known as "Private browsing"
Refer to:
http://help.opera.com/Windows/12.10/en/private.html
Hope this will resolve your issue.
GuruAid.com
Jul 13, 2014 | Computers & Internet
Tip
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will...
In the next few posts i will post some tricks to make your phone faster and also recover precious RAM.
1. MOVE HELP FILES TO MEMORY CARD
If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card.
Enable CAPS OFF
open Xplore or fxplorer and move C/resource/help to E/resource/help.
All the apps will find it automatically in the E drive.
This trick will increase your phone memory thereby making your phone a little bit faster.
2. DISABLE LIFEBLOG PERMANENTLY
first use jbak taskman to kill lifeblogobserver process
make sure x-plorer is set to show hidden files
then go to c/data/lifeblog/database
now delete the lifeblog.dbfile
reboot phone
now use jbak taskman to kill lifeblogobserverprocess once again!
select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM.
if you want to use lifeblog again go toc/data/lifeblog/database
and untick hidden and read-only
3. STOP AUTO STARTUP OF APPS ( for a faster boot up)
You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process.
The info of all the start up apps is stored in c:\private\100059c9\start.dat
whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating.
When ever you again want to enable the startup apps just remove the .txt extension.
You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it.
The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want.
You can even further boost up your phone start up by renaming files like
C:\private\100012a5\DBS_101F99FB_NSmlDSSettings.db
C:\private\100012a5\DBS_101F99FB_nsmlagentlog.db
C:\private\100012a5\DBS_101F99FB_NSmlDMsettings.db
C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b
C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat
C:\private\101F99FD\nsmladapterlog???.dat
C:\private\101f9a06\nsmldmtree.db
C:\private\100056cf\clockapp.dat
C:\private\100059a8\nitz.dat
C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db
C:\private\100012A5\101f8683_ScShortcutEngine.db
C:\private\1000850\logo*.*
C:\private\100012a5\DBS_10205030_accpolicydb.db
C:\private\1000c959\localdata\commondata.D???
C:\private\1000c959\localdata\localdata.D???
To .txt files or simply delete them.
Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
on May 09, 2010 | Cell Phones
How can I call back a private number on my vtech house phone
You can't. When caller-ID shows "Private", it means that the caller does not want you to know what number they are calling from. (Tip: These are good messages to let the answering machine answer. If they want you to call back, they'll have to leave a number.)
Jan 31, 2014 | Vtech Cordless 6041 Phone
I need to make my number private on my lg optimus. How do I do it?
I have a LG P-500 does anyone out there know how to put the phone on private number or witheld?HELP PLEASE
Apr 08, 2011 | LG Cell Phones
Private Number Calling
I am seeking assistance in regards to how to find the private number calling on my Nokia E63 mobile phone. I know there is a way to do it but somehow I could not find it out. Please help.
Jul 29, 2010 | Nokia E63 Cell Phone
People keep calling me on a private call and i need to know there nuber to call them back how do i go about doing that
Usually private calls made are from a phone card so basically you cannot return the call. Hope this helps
Oct 21, 2009 | Cell Phones
Marked Private Contact
Hi, to see the private contacts in E8 follow the given procedure:-
Main menu >> Contacts >> Option >> Setup >> Private contacts.
Uncheck it to get your private numbers back.
May 17, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Block private calls
this will solve your problem
http://www.trapcall.com/features
or find out who is behind the calls with this feature
Apr 21, 2008 | RIM BlackBerry Pearl 8100
Private Phone Calls
doesent it have a mute button or a att button?
Dec 22, 2007 | Pioneer DEH-P7900BT CD Player
Cell Phones Logo
162 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
