Question about Electrical Supplies
Why ups output voltage is vary 215 from 221 - Electrical Supplies
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Can you give more details.
Type of UPS and age.
Does the variation depend on the load?
Posted on May 08, 2017
I am use one kva ups ups output voltage is vary solution
Please give more details.
May 08, 2017 | Computers & Internet
Having trouble with all my speakers except my twitters in a 2007 Saturn Outlook...what do I start with? Fuses are good
Speakers get power from the amp if your system has one or from the radio , if the tweeters work it's not a fuse problem . You like listen to your stereo loud . Blew a channel in the radio or amp ?
Take it and have it checked for DTC'S - diagnostic trouble codes
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier (if equipped) have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5 V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3 V AC and slightly higher.
Do you know how to do DC voltage testing ?
Without Amplifier without UK6
Ignition OFF, disconnect the harness connector at the appropriate speaker.
Radio ON, test for 5.0-7.5 V between the signal circuit terminal A and ground.
? If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
? If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
Test for 5.0-7.5 V between the signal circuit terminal B and ground.
If all circuits test normal, replace the speaker.
Dec 25, 2016 | Saturn Outlook Cars & Trucks
Videocon ultraslim tv picture widith expands after 10 mimnutes all pf changed in h out section
Check whether the SMPS output varies after 5 minutes working. Might be. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Oct 06, 2016 | Televison & Video
Motherboard, the inverter output voltage
Inverter output can vary, but anything greater than 150 volts with a high impedance meter (with a capacity of 2000 volts) can be considered good. The meter loads the circuit by itself and normally the RMS voltage that most meters register is lower than the peak to peak voltage of the circuit. If a scope is used, use a 10:1 reduction probe, and your voltages can be anywhere from 300 volts to 1200 volts with 650 to 750 being the normally accepted good range. Where your brightness control is set will have direct impact on the voltage you see.
Nov 01, 2012 | Acer Aspire 5920-6727 Notebook
From yesterday, three spots (red, green
Check the electrolytic capacitor smoothes the video output voltage for value deteriation. Replace it, In most cases, this capacitor can be located at the video output circuit board [Picture tube base board]. The value of it may vary from 10MFD 350VDC to 47MFD 350VDC.
Locate this capacitor. In some sets, it can be located at the main baord itself. Anyway, this is the video output supply voltage smoothing capacitor.
May 15, 2012 | Televison & Video
My 2006 fuel injected fat boy stop charging above 2000 rpm. are there aftermarket voltage regulators that will work with the variable output the stator puts out or do I have to pay the 150 bucks for a...
As far as I know, ALL alternators are variable output to a certain extent. Not as bad as a generator but still, if you connect a volt meter to the output of an alternator and vary the speed at which it's running, the voltage will vary. There are other voltage regulators that will work on your bike. Custom Chrome's brand is C.C. Rider and Accel makes them as well. They cost as much as the OEM regulator but in my experiences, they don't last as long either. Does made in China mean anything to you? Not trying to be a wise acre here just trying to point out that quality isn't cheap and in that area, I've had much better luck with genuine H-D parts.
Good Luck
Steve
Sep 03, 2010 | 2006 Harley Davidson FXDBI Street Bob
2005 Corolla P0420Did live data; oxygen sensors B1 S2 varied between .195v and .800vB1 O1 varied between 3.161v and 4.209v but stayed mainly around 3.2 to 3.3v I did the "bang" test on the cat and it does...
If you have a scanner try doing an active test on a/f control. Switch the injection volume between +25% and −12.5%, then read the A/F sensor and oxygen sensor voltages. If both sensors react then they are not the issue. Your O2 sensor should vary .4v - .6v and your a/f sensor should vary 3.0v - 3.35v. The A/F sensor output has a few seconds of delay. The heated oxygen sensor output has 20 seconds of delay at maximum. Otherwise is could be an exhaust leak.
Jun 25, 2009 | 2005 Toyota Corolla
Test vehicle voltage while driving
if your just trying to test your altenator output of your vehicle just place the two terminals of the multimeter to the battery and u should get a good general output voltage that shouldnt vary much from when you drive since the the altenator has a regulator in it
Jan 15, 2009 | Ford Explorer Sport Cars & Trucks
JVC 36" TV will not power on and has a blinking power light...
Hi and welcome to FixYa,
Almost always, when an electronic device/equipment fails when powered with and by a generator, it is the power supply unit (PSU). The PSU circuitry expects a fairly constant/stable power source (120 or 220). The output of the generator tends to fluctuate especially under varying electrical load. Additionally, the AC frequency (60Hz) of the generator's output also tend to vary which most PSUs don't like. A noteworthy point to consider is that the generator is floating electrically, its output has no reference to earth/ground.
If you are considering a DIY (do-it-yourself), foremost to inspect would be the PSU particularly the regulator transistor and determine if it outputs +5 and ~+135 VDC. Another to check would be the HOT (horizontal output transistor). If when the TV was used powered by a generator, there was considerable vertical rolling, the vertical deflection IC would also be a suspect.
A friendly reminder, exercise caution when repairing TVs. It stores up EHV (extremely high voltage). It would be to your advantage to reference a service manual (JVC AV-36D303) or at the very least a schematic diagram with voltage readings.
Good luck and Thank you for using FixYa.
Jan 05, 2009 | JVC AV-36D303 36" TV
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
