Question about Dryers
Which way is the top of the hamersley baffle plate
Baffle plate for Henden wood burner
hi alistair.
not sure if this is what you are after,but go to this link and see if its what you are looking for.
Baffle plate for Henden wood burner Google Search
Nov 03, 2017 | Cars & Trucks
How to replace baffle inside tumbler
some baffles have a screw at the far end inside the drum. remove screw and push baffle to remove. If you dont have that type of baffle then you would have to open the top cover and tilt back. You will be able to see the screws that hold the baffles. some tops have screws in the back to remove top. Some have clips in the front that would need to be push in with a small spatula. Good luck. I dont know if your able to post pictures with your question, it would really help.
Nov 18, 2015 | Bosch Dryers
Austwood wood heater cannot remove top baffle plate in the firebox
you dont remove it,you dont need to clean it besides tapping the creosoot off,it burns it off
Apr 03, 2014 | Heating & Cooling
Baffle plates
baffle plate for the flupipe or what..
Dec 16, 2013 | Pool & Spa
Napoleon NZ26 woodburning fireplace smoking back.
Get someone to come and do this correctly. You have a possible carbon monoxide poisoning hazard!!
Nov 18, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
How do i disassimble and replace the flappers on the kreepy krauly pool cleaner..tks.. steve
Removing the flapper is pretty easy on these automatic pool cleaners. First, with the cleaner upside down, lift the lip of the foot pad and insert a flat-head screw driver along side one of the two tabs found on the baffle plate. Push the tab inward with the screwdriver until the baffle plate releases. Place a finger into the center opening of the baffle plate and pull up until it pops out. Then pull the flapper
out. You should be able to do this without removing the foot pad.
May 06, 2011 | Universal Kreepy Krauly In-Ground Pool...
WHAT IS THE REASON FOR BAFFLE PLATE IN OIL PAN AND DOES IT NEED TO BE PUT BACK IN AFTER REMOVE I DAMAGED MINE WHILE TAKEN OUT
The baffle plate serves a couple of purposes including reducing oil slosh during turns. More importantly it adds to the stiffness of the block and is a necessary component and will need to be replaced.
Jan 26, 2011 | 1999 Kia Sportage
We do not seem to be getting as much heat from the stove this year as last year. The stove makes a loud clanking sound when it heats up and cools down. It is a regency wood stove Model R3/R9/RA3. There...
That stove has a metal baffle on top of an air tube that can warp with age. It might be changing shape as it heats up and making your sound. If this is the case it can block the path for the stove pipe and cause performance issues. The baffle plate and insulating blanket on top can be easily replaced.
Dec 07, 2010 | Stoves Heating & Cooling
Rainbow se d4c
There a number of screws that you have to get out. Maybe a screw extractor may work, last resort would be to drill the heads off of the screws, then after the plate is off, remove what is left of the screws.
Feb 16, 2008 | Vacuums
Dryers Logo
Top Dryers Experts
