Question about Haier Heating & Cooling
Haier AC auto restart problem - Haier Heating & Cooling
Why the AC flash stop and doesn't start, AC MODEL-CPR09XH7
Seems to be internal error its not working kindly its turn off the power supply and connect it again restart. Hope it will works
Jul 16, 2016 | Haier Heating & Cooling
My AC haier say EO what do I do
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you have any other AC Repair Questions don't be afraid to let us know.
Jul 07, 2016 | Haier Heating & Cooling
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
ZCF/LW-17-2 Remote Control AC-5620-36
Following amazon item link can be compatible for your Haier ZCF/LW-17-2
What's important is that it display in Fahrenheit.
Other ebay or amazon sellers sell replacement in Celsius
Amazon com Replacement for Haier HRRM Air Conditioner Remote Control Model...
Jul 28, 2013 | Haier ZCF/LW-17-2 Remote Control...
Restart
This is a safety feature to prevent restart if there is a short power stoppage of 2 mins or less as it could dammage the compressor
May 24, 2013 | Haier Heating & Cooling
My ac is not on auto but it keeps turning off and on
Typically a thermostat has three settings. fan setting -on / off. System setting -heat / off / cool. and your temperature settings. Does the outdoor unit turn off and on but the fan runs, fan setting is on. Check your thermostat settings.
Sep 15, 2012 | Haier Heating & Cooling
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
Apr 05, 2012 | Heating & Cooling
Fills with water, doesn't evaporate. Leaks. HAIER HPR09XC7
There is nothing to resolve. Your humidifier is working properly.
A humidifier works by condensing water out of air. This is the job of the cold coil, which you have found to have water dripping off. The Warm coil is not intended to re-evaporate the water, as this would just bring the relative humidity back to the origanal high level, rather, the warm coil is used to re-warm the air, going back into the room so the room does not get too cold. It is normal to have to empty the bucket and restart the process on a periodic basis.
Jul 20, 2010 | Haier HPR09XC7 Portable Air Conditioner
Getting an e1 code after the power went out is my ac just shot, its the haier hwr08xc7 any ideas
getting an e1 code after the power went out is my ac just shot, its the haier hwr08xc7 any ideas
Aug 20, 2009 | Haier HWR08XC7 Air Conditioner
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
