Question about The Audio Players & Recorders
Sokkia set 610 what is the problem of error 195 and error 190
In Sokkia CX 101 Total Station Error E097 comes ....What is it means and how to solve that ???
CX series
www.sokkia.com.tw/download/??/CX_series_E-copy.pdf
Jan 1, 2012 - CX-105. CX-107. Compact X-ellence Station. CLASS 2 Laser Product ... Except where stated, "CX" means CX-101/102/103/105/107. • The CX ..... Ignoring this indication and making an operation error .... Make sure that moisture or dust particles do not come in contact with the inside .... detergent solution.
Mar 21, 2017 | Computers & Internet
The lcd displayed E190 error. i want to know the problem
The E 190 message means there is an error in the horizontal encoder. You need to contact the Sokkia service.
Apr 06, 2016 | Sokkia Set 610 Series Total Station Topcon...
E191 for total station, sokkia type, it does not observe horizontal and vertical angle & does not measuring
Sokkia total stations are repaired using Sokkia proprietary computer software. You need to return it to a Sokkia shop, no other shop will be able to corect this, not even Topcon (even though Topcon bought Sokkia).
Jul 29, 2015 | Sokkia CX-105, CX series, Total Station...
What is meant E024 error code of SET550X SOKKIA total station?
Hi Aung,
E024 is for F4 cal level error.
what this means is that one of the frequencies used in your distance measurement needs adjustment. This adjustment can normally be done as part of your annual service.
Not having it serviced for a long time is often the reason why these types of error will occur....
rgds, Paul
Jun 09, 2014 | Sokkia Set550x Total Station, Two Years...
Error e191 sokkia 1030r
Sokkia 1030r displays e191 in horizontal angle window
Jan 19, 2014 | Sokkia Set210 / Set310 / Set310 / Set510 /...
How to download the files from sokkia total station 1030 r
To Down load pls let me know com set up (Sokkia 1030R instrument)
BAud rate ,parity & Bits
May 18, 2010 | GPS
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Aug 12, 2009 | Leica Disto A6 Laser Distance Meter
35 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
