Question about Radio Communications
I have a camera with 1,yellow 1,red Leeds n 1 short antennae 1small mic how do i wire it up
One Wire
  • 126 Answers
SOURCE: connex 3300 mic wiring
I opened up one of my Cobra HighGear mics and here is how it is wired:
1. shield (Bare copper wires) --- twist them good and tin with a little solder
2. audio (White)
3. transmit (tx) (Red)
4. receive (rx) (Black)
Blue and Yellow are unused.
Dean
Rollin CBs
Posted on Jan 28, 2008
  • 6 Answers
SOURCE: wiring/ i am lost
http://homepage.ntlworld.com/rg4wpw/astaticbook.pdf
Posted on Jun 16, 2008
SOURCE: CB MIcrophone RewireJob. A Diesel Model 360-100 to cobra's
does it have a sheld wire?
Posted on Jan 14, 2009
  • 75 Answers
SOURCE: Color code for 4-pin Cobra M75 CB Mic
here is the link that i used
hope it helps
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=8197
Posted on Jul 03, 2009
  • 219 Answers
SOURCE: RK mic to RCA co-pilot CB
yellow is a dead wire don'r worry about it
red and sheid braided 1
white 2
blue 3
black 4
numbers by holes
Posted on Nov 21, 2009
I have a uniden grant xl the older one. i have spent 36 hours looking for a wiring for a m75 cobra power mic and have tryed lots and none work. i cant even get wiring for a stock[ cobra mic red white
it doesn't make a difference what color wire it is as long as the wire is connected to the function it is going to control If your mic has a red , blue , black , and shield wires but your radio isn't set that way you have to set it to the way your radio is . you have to find out where ground is then audio in and audio out then the last is the shield.
Jun 10, 2012 | Cobra Radio Communications
NEED TO WIRE LESON MICROPHONE TO MAGNUM 257
Notice the black mic plug has the numbers it is solder by numbers. Used rosin core silver solder radio shack sells it.
Mic Wiring
Stock
1-Shield (ground)
2-Yellow (audio)
3-Red (transmit)
4-White (receive)
Astatic
1-Shield & Blue
2-White
3-Red
4-Black
Yellow NC
Turner Roadking 56
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC
Sadelta the is a BASE mic
1-Shield
2-White
3-Brown
4-Green
Oct 02, 2011 | Magnum 257 CB Radio
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
Galaxy DX 98VHP meter stopped moving . There is no swr reading, nothing. Even with a seperatye meter atached or a dummy load, the meter on the galxy is not working. Did I lose all power?
You appear to be aware of you antenna system with the separate meter attached so the tells me you dont punish a radio with an high swr. I am just guessing red wire/solder in mic cord at plug given that it is a side mic mic jack.
Stock mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Jul 02, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
RIPD CAMERA WIRES!!!
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Jun 01, 2010 | Lorex SG6153 / Weather Resistant Mini...
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Speaker wire diagram
Constant 12V+ White/Yellow
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger Yellow/White
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Feb 18, 2009 | 1992 Honda Accord
Wires pulled off a cobra mic 75wxst 5 pin connector
1) violet 2) blue 3 ) shield 4) yellow 5) grnd Violet inside the mic is the power wire . Blue and yellow are the internal and external speakers. the other wires are to the antenna
Dec 26, 2008 | Cobra 29 LTD CB Radio
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
