Memory back up system to solve. - Computers & Internet
Oop's system error has ocurred restarting
mY Dear:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Dec 23, 2012 | HTC F3188 Smartphone
Memory problem(system unit)
what is the memory error message? are you getting an error message that says memory is running low? if you got this message, do an upgrade with your memory. that will solve the problem.
Jul 10, 2011 | Microsoft Computers & Internet
System date error on rv4 card
quale e' la soluzione a questo problema?
Apr 19, 2010 | Nintendo DS Lite Console
DSi system date error please check NDS system data
Remove the cardset the date to 01/012009 on your consol. Put the card back in and it should work
Apr 17, 2010 | Nintendo DSi White Console
My memory card is corrupted how i can repair
Memory card corrupt errors occur when ejecting without safely removing
from system or from phone which causes some files delay write fail
Your memory card problem can be solved in many ways
1.Insert the memory card in card reader and
in windows xp go to the drive properties of memory card by right clicking the drive and select
the tools TAB and select "Check now" as seen in check errors
and tick both " Automatically fix file system errors" and " scan and recover bad sectors "
click start and it will fix all file system errors
and all your data is safe too
2. another method is format your card. but it will erase all data
hope this will solve your problem
Feb 28, 2010 | Computers & Internet
At boot up my Dell Inspiron 8000 laptop gives a "Memory write/read failure" error message and will not continue booting. How do I solve this error and boot the laptop?
Check your memory, On the bottom of the computer is a small door to access the computer main memory. Check to see if it is not knocked loose - reseat it. and then it may be bad -and will need to replace it.
Nov 17, 2009 | Office Equipment & Supplies
I have a intel D845GLVA. When I turn it on I get 3 long beeps, and the monitor will not display?
You have either a memory failure or keyboard / keyboard controller or card error.
Unplug the keyboard from the computer and try turning it on.
If that doesn't solve the problem then its most likely the memory. Try re-seating the memory modules, and try with just one module.
If the problem is still not solved, take all the ram out, start up without ram and then place one ram module back in.
Remember to unplug when you are working inside the computer or changing parts
Thanks and good luck
May 02, 2009 | Computers & Internet
Diagnostic test Error 000480
..but, other than deleting memory;opening battery swing-out door with cam on;turn off;close door; turn cam back on...this may or may not solve prob.
Ron L
Apr 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
System will.not post
Can anyone help me pls. fix my problem. My P5PE-VM Asus Motherboard having a problem error loading operating system. I replace my RAM, power supply and hard disk drive but seem's the error is not fix....I'm out of idea can anyone knows it and solve the problem.. I appreciate to thanks in advace!!!..
May 10, 2008 | Computers & Internet
there might be a problem with the file system you are using with with memory stick..insert it into card reader > format it with fat 32 file system..and insert it again to solve your problem.....if problem still persist .insert your memory card into mobile and goto your memory card > now select option > there you will see format memory card > so it will format your memory card with correct file system that your mobile wants.....
Please let me know your feed-back.
Technical Associate
Apr 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Computers & Internet Logo
David Payne
David Payne
