Question about Air Tools & Compressors
In my workshop compressor -Atlas Copco- GA110 - stop running after few minutes and showing " Stator feed back contact open " on display
    Novelist:
  • 214 Answers
That would be starter feedback contact. You have a bad aux. contact on the side of the starter. Remove and replace the aux. contact.
Posted on May 15, 2017
SOURCE: compressor is loading without unloading
Can we save energyIf we decrease the loading pr. of a vertical 125 CFM air compressor from 6.0 kg/cm2 to 5.5 Kg/cm2. If yes how much energy we can save if compressor have 30 KW motor
Posted on Nov 05, 2009
miket756
  • 2702 Answers
SOURCE: air compressor atlas copco ga30 oil seeping out
you should have an oil trap or two in the line from the out let of the compresor before it go's into the factory
they also trap any water in the air there easy to fit into the line and not very pricy
Posted on Feb 11, 2010
compman66
  • 169 Answers
SOURCE: the air compressor xats 67 starts, runs but cannot
suspect that the inlet control valve or control regulator may be at fault, but are you sure that your demand is not more than the compressor can deliver? if you close off the service valve will it come up to pressure and idle back as normal? if so then you may have a leak in your system or your demand is to large. But having a knowledgeable service tech check it out would be the next step.
Posted on Feb 16, 2010
  • 243 Answers
SOURCE: Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Posted on Mar 03, 2010
SOURCE: electrical schematic for xas 56 atlas copco
whith serial number I can provide the wiring diagram
Posted on Jan 02, 2011
What is reason for starter feedback contact open and what is the solution for this in atlas copco ga110 compressor
so without having a meter on this my first idea is the motor starting contact relay saddle mounted contacts either have a wire loose, broken, or the contact itself has failed and not sending the feedback to the plc that the motor starter has in fact closed to start the motor, one way to trouble shoot this is to manually close the motor starter and ohm out that particular contact set to see if this shows it closed. do this with the power off as when you close this manually it will try to start the motor. ohi it before and after u manually close that starter relay.
Nov 14, 2017 | Air Tools & Compressors
We want a control panel Part No. 1604 9422 02 Xc2002 for our atlas copco air compressor XAMS 850 CD7. Can you help us on that.
we don't sell parts for anything
contact your atlas copco service center for the parts or get them from e-bay
Sep 20, 2016 | Air Tools & Compressors
I need an operating manual for an atlas copco ZT145 compressor with the elektronikon grapgic plus control panel. I need to change the setpoints.
One of the regional Atlas Copco websites should be able to help or perhaps the mother site.
Just use google.
Feb 17, 2015 | Air Tools & Compressors
Atlas copco troubleshooting
If pressure on display is higher than set pressure of your safety valve,then your safety valve is doing its job. If pressure on display is lower than set pressure of your safety valve,then your safety valve is defective.
Aug 06, 2014 | Atlas Copco GA Rotary Air Compressor...
Cfgf 3 fault on display atlas copco GA 45
alternately flashing messages [CF GF] and [3] - this is Electronicon Controller software error - probably the controller memory has been erased by a short circuit or something similar, sorry for the bad news
Jan 28, 2014 | Atlas Translator Atlas Copco Air Hammer...
ATLAS COPCO GA45+FF. COMPRESSOR SHOWING OVERLOAD MOTOR/FAN MOTOR. HOW CAN WE RESET
Could be the unloader valve did open, Unhook the motor from the compressor and see if you can turn the motor on, then see if the compressor can be turned by hand
Jun 13, 2013 | Air Tools & Compressors
Xas125 atlas copco compressor
check with atlas or atlas dealer. I would be guessing but most labels include the capacity in the model. So xas is the model and 125 is the capacity in cubic feet /minute
May 09, 2013 | Air Tools & Compressors
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Air Tools & Compressors Logo
112 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
