Question about Cell Phones
How do I change the language on my hm7000 Bluetooth
  • Mohammed Ebrahim M
    Mohammed Ebrahim M May 08, 2017
    Change what language? This headset doesnot have any display to show any language.
Mitsubishi multi communication system outlander Change language to English
If it has bluetooth try this hope it helps.
1. Press and hold the multi-information meter switch for about 2 seconds or more to switch from the setting mode screen to the menu screen.
Refer to "Changing the function settings (when the ignition switch is "ON")".
2. Lightly press the multi-information meter switch to select (language cooperative control).
3. Press and hold the multi-information meter switch to switch in sequence from A or 1 (language cooperation enabled) ? M, 2 or P (language cooperation disabled) ? A or 1 (language cooperation enabled).
The setting is changed to the selected condition.
Note
? The memory of the language cooperative control is erased if the battery is disconnected, and it returns automatically to A or 1 (language cooperation enabled).
? The language display modified with the language setting can be switched in the following manner.
• When A or 1 (language cooperation enabled) has been selected with the language cooperative control, the language for MITSUBISHI Multi-Communication System (MMCS) (if so equipped) or the Bluetooth® 2.0 interface (if so equipped) is automatically changed to the language selected for the multi-information display.
• When M, 2 or P (language cooperation disabled) has been selected with the language cooperative control, the language for MITSUBISHI Multi-Communication System (MMCS) (if so equipped) or the Bluetooth® 2.0 interface (if so equipped) is not automatically changed to the language selected for the multi-information display.
Jan 26, 2016 | Vehicle Parts & Accessories
Samsung HM700 Bluetooth Headset's light keeps flashing red and blue and can't hear anything, the person on the other end can't hear anything either. Tried re-pairing, but it doesn't work.
Pairing is not the same thing as connecting. The LED will go solid when you complete the next step which is connecting. With headsets that is usually done via the audio source device.
Mar 07, 2014 | Google Samsung HM7000 Bluetooth Headset
Change language on bluetooth
How change language in bluetooth hyndai tucson 2010 from esp to eng?
Dec 29, 2012 | 2010 Hyundai Tucson 2.0
I need to change the language to english and need to access blootooth
go to "settings' in your phone and choose "phone" option in it. then choose "language selection" in it. change the language to english. enjoy it. then go to connectivity in settings of your phone and select bluetooth then followed by visibility in that. also enjoy bluetooth. thank you.
Jan 02, 2011 | Cell Phones
How can i change the language in my blueant 3?
Hey Nessa,
If you are posting this under ST Light, this is wrong it should be listed under the supertooth 3. To change the language of the device delete it from any phone it is paired with in range. Once this is done, with the device off, hold down the green button until you hear a language loop. When you hear the language of your choice, let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go to your bluetooth menu, search for devices, select the Supertooth 3 and enter the pin code 0000 if prompted.
Rylan
Dec 07, 2010 | Blueant Supertooth Light Bluetooth Speaker...
I have laptop acer Extensa 4630Z , my windows is in english language but the bluetooth is in arabic language,i want to change bluetooth language from arbic to english,i install bluetooth driver again but...
check your region and language; try setting it for a country that speaks English and then take a look, make sure the interface is installed in English, the drivers could be in any language but I do not think this has nothing to do with the interface.
Dec 27, 2017 | Acer Aspire 5610-4648 Notebook
HOW TO CHANGE THE LANGUAGE on parrot ck3100?
download update from parrot website, select the correct language on update software then update the parrot via bluetooth on computor/laptop
Jun 16, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Language changes
You will need to preform a software update with the new language you require, go to www.parrot.com and click support. you will need a computer with bluetooth conectivity to do this.
Jan 06, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
