Question about The Computers & Internet
The heater is not working in my 1997pajero what do Ido to fix it?
Why do flame come out of unit blowing the pilot out. what do ido
have the heat exchanger inspected for any holes.
check gas pressure 3.5 natural 10 propane, have vent system check for blockage.
Jan 28, 2015 | Cozy Heating & Cooling
My password cannot work .can Ido not use passwordperson
You must enter the correct password then remove it.
Sep 08, 2014 | Computers & Internet
Why my 1993 acura legend blow's cold air but not hot air,the AC works fine.The cooland level is good too.What can ido to fix this? too cold to drive the car like this,please help...
It sounds as though your heater core is stopped up, have someone intelligent to drain your radiator and catch the antifreeze because of animals drinking it, it will kill the animal, then flush the radiator & heater core with a flush designed to cleanse the system, follow directions from flush manufacturer, then put the correct amount of antifreeze in your radiator. Wal-Mart or any parts place will have this in different brands. This may help, it did on my 1998 mercury Mystique.i hope this helps you
P.s. Just follow directions on the flush container & this can be done by the do-it yourselfer
Make sure you allow the engine to cool before pouring the new antifreeze into the radiator, could burst your engine block.
Jan 15, 2013 | 1993 Acura Legend
How can ido my ipad1 files all accidentally deleted
Did you use your iCloud account to backup your iPad? If yes, then you'll be able to restore it from there.
Dec 18, 2012 | Apple OSX 10.3 for Unix, Mac
Hi i have recently perchased 96 taurus whish the check engine waring lights stays on but the cars runing fine what can ido to fix this problem
The obvious
Have a repair shop work on the problem
If you can get wiring diagrams,read them &
do your own testing-- then have at it
Dec 13, 2012 | 1996 Ford Taurus
Solution to solve system Error E007 on IR 2016i copy machine
The fuser unit needs replaced. You need a tech with a new fixing unit.
Dec 24, 2010 | Canon iR 2016i Black and White Copier
Rear heat and a/c blower
I sounds strange that both blowers do not work. The A/C blower is in the back of the van, the heater is behind the driver at floor lever. Maybe a power line has came off behind the two switches in the center console. Check the fuses again just to be sure (under the hood on driver side). The daytime running lights will shut off if you depress the parking brake - check if it is fully released. That switch on the parking brake lever would be the first thing I check.
Jul 18, 2008 | 1999 Chevrolet Astro
Computers & Internet Logo
50 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
