R
Robert L Turnage Posted on May 08, 2017
Defective Priceless and defective Seven alone. return clean playable replacement
I HAVE A 606 MODEL RICCAR AND THE DIALTENSION DOES NOT WORK.I TOOK APART AND I HAVE NO INSTRUCTIONS HOW TO RESEMBLETHE Pieces. I called a repair place and the want$100 IS CRAZY CAN YOU PLEASE ADVISE?
Um, you can try searching for:
Make Model parts diagram
Otherwise, $100 for a service call on a sewing machine is pretty standard. If you haven't had your machine serviced in quite a while, it may be a good time to bite the bullet and get it cleaned, oiled, and adjusted and also repaired by a professional.
tip
Replacing igniter
GE wall ovens have panels for regulator and ignitor wiring at the lower back of oven. remove all screws and plates to expose wiring. clip off defective igniter and use ceramic wire nuts to fasten new one. re-assemble.
I learned from local gas company that igniter is most frequent part to replace.
cost = $35
GE technical support = non-existent.
power of the internet - priceless!
CD player says reading disk about three times after a cd is put in and then the cd is ejected and the message says "not playable." we have tried to clean the head, but it also ejects the...
You can try clean the optical lens by removing Bose top cover ( make sure power off your device before remove the cover). Now instead of using cleaning disk, you can using cotton **** with cleaning lens liquid. Wipe clean the lens ( 2-3 times). After it gets dried, you can try your device. If still no joy, your optical lens is defective and need replacement.
Regards,
1helpful
2004 GMC Envoy check engine light remains illuminated. Diagnostics revealed codes: P1133 and P0128. P1133 points to a heated oxygen sensor and P0128 indicates a possible defective thermostat. The O2 sensor...
Leave 02 sensor alone ,it is doing it's job . It is heated up because of lean fuel mixture due to incorrect engine temp.,replace thermostat before looking further.
I just purchased a factory serviced model TR-520 bread maker and the paddle provided does not fit the drive shaft. The drive shaft is about 1 cm diameter, and the hole in the paddle is only about 8 mm...
Satisfaction Guaranteed on all orders:
We are happy to fully refund purchases if an error has occurred in your order or if an item you ordered is defective. If you aren't happy with the product you received or are dissatisfied for any reason simply return the item within seven days for a full refund minus a 15% restocking fee. Please call us or email us within seven days of receiving your order for information on where to ship items that need to be returned. Do not return them to our P.O. Box.
The returned product must be in new and unused condition, in the original box with all the documentation, parts and accessories to insure full credit. "New and unused" means sale-able condition, not dirty and not washed. We cannot accept returns for an item with any indications that it has been used.
Return shipping costs are your responsibility unless the item is damaged or defective. If you have any questions about the restocking fee as it pertains to your order please call us before we ship the product as once it leaves the warehouse we have incurred our cost.Fax Number: 1-866-323-8256
[email protected]
http://www.bread-maker.net/contact-us.aspx
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Loading games
possible optical pickup assembly defective, get some canned air and try blowing dust and debris from the drime assembly, this may give some limited playability, I the laser is defective it will need to be replaced and with the plastic rack gear located on the laser itself
1helpful
Burning DVD-R playable on a stand-alone DVD Player using Nero Express 6
http://www.softpedia.com/get/CD-DVD-Tools/Data-CD-DVD-Burning/Nero-8.shtml
please go to the above site and download nero 8 which is more advance and enter the any of the keys
9K20-7839-0295-6KA4-5008-1KM3-8C64 (the one i recomend)
1K22-0867-0795-66M4-5308-3698-EE5M or
1K22-0867-0795-66M4-5251-9214-3AC7 or
1K22-0867-0795-66M4-5765-3212-7AA2 or
1K22-0867-0795-66M4-5085-3781-ACK0
good luck
k24674
ADMIN Andrew
ADMIN Andrew
