Question about Sewing Machines
4210 stitches without problem for about 4 inches, then slowly grinds to a halt.
  • Sewing Machines Master
  • 11,482 Answers
Am wondering if there is a problem with threading--ie, mis-threaded, thread looped around thread guide or the spool pin, thread catching on a burr. Remove all the thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Otherwise, may need service.
Posted on May 08, 2017
The thread on my Elnita sewing machine keeps coming out of the needle and won't sew. How can I fix this?
Make sure to pull at least 4-5 inches of thread through the needle eye before beginning to stitch. It will help to also hold the thread tails in your left hand while slowly taking the first few stitches. Another help is to raise the needle to its highest when starting to stitch.
Nov 17, 2017 | Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Why won't my sewing machine produce a zigzag or decorative stitch?
sometimes u have to sew on scrap for a few stitches for the computer to recognize the stitching has been changed. Then it might break through Hope it works for you
Aug 25, 2014 | Singer Inspiration 4210 Mechanical Sewing...
I have the Mega Quilter and Quilters Cruise Control. My stitches are very inconsistent.
I agree to have the regulator check, & even having the whole machine checked wouldn't hurt.
May 15, 2012 | Sewing Machines
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
Just purchased a 4210 and having problems. The fabric will not move forward. I have adjusted the stitche length and tension with no luck. I don't think the feed dogs are moving.
Is you presser foot down all the way? Have you looked at your manual for dial settings? I was kind of confused when I saw how you had to set you stitch selector, double check that it is on the lines with the circle in the middle and not on something else. If, that don't work, take it back to the where you bought it.
Dec 31, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Singer 4210 does not work: it is plugged in, the light is on, but when pressing the pedal nothing happens.
Make sure that the foot pedal is correctly inserted and that you have selected a stitch pattern. Also, recheck your threading, totally rethread if needed, bobbin also
Sep 12, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Not problem-question
Different stitch lengths are used depending on what you're sewing. I would say 2.5 is the "normal", "average" stitch length for basic sewing. If there are certain types of fabric you're using that ravel or come apart easily, you would use a smaller stitch length, which means more stitches per inch. If you want to just baste fabric together without having a permanent seam, you woould use the highest number, to have the least amount of stitches per inch.
Mar 17, 2009 | Juki MO-644D Mechanical Sewing Machine
Two Stitch Hang-up
youch!  how frustrating.  It sounds like there is a piece of thread caught in or around the bobbin casing.  take the whole casing out and clean with your brush.
I feel your pain, hope this helps.  If not, please come back and we'll try some other things.
Jan 18, 2009 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
