Question about LG Lands Phones
I have the LED light pad model L 4S and have lost the power cord but my LG charger cord works.
Power hook up cord? My LG telephone mobile unit cord works fine but I want to make sure that it is compatible with the light tablet
  • 143 Answers
SOURCE: comtrend ct507 no power
- try to use a known working power adapter with the same specs, it might be the power adapter is not supplying enough power, or
- try to press the reset button (if it has one) for like 30 secs, then turn the device off for another 30 secs. (Note: this might delete all the settings on the device)
- most probably the device is dead if same thing happens after pressing the reset button.
hope this'll help you
Posted on Jun 10, 2008
  • 136 Answers
SOURCE: Computer dead despite working power supply (power and charger LED are off)
Try removing the battery. It might be damaged and overloading the laptop. Also, before you replug the AC cord, press power for at least 5 seconds.
Posted on Nov 02, 2008
  • 2326 Answers
SOURCE: Olevia 540-B11 - no power
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to if you require further assistance.
Posted on Jan 07, 2009
  • 659 Answers
SOURCE: Amana air and heating unit model # ptc153b50am w/ power cor 37470
Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
Posted on Mar 17, 2009
  • 58 Answers
SOURCE: HP G60-230US lap top won't turn on
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
If the issue persists after the above steps, then this could be due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. If your notebook is covered under HP Standard Warranty, then I would request you to contact HP Support to get your notebook repaired under warranty.
I believe the information provided would be helpful to isolate the issue with your notebook.
Posted on Jun 07, 2010
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Fuse Blows
does the unit works at all?
Dec 11, 2007 | Lowrance Iway 500c GPS Receiver
Why wont my motorola photon q phone charge or power green light comes on at all
Your charge cord may fit, but it may not be configured to your phone. I just bought a new Nexus phone that has the same charge port as my older Galaxy 4s phone. The Nexus charge plug fits into the Galaxy 4s charge port with no problems but does not charge after plugged into outlet. But the older charge cord will work with the new Nexus charging wise but data transfer will not work. So you may have a charge cord that plugs into phone, but may be configured differently due to phone manufacturer. Hope this helps.
Dec 19, 2014 | Motorola Cell Phones
Power cord
if you have extra chargers that work check them out to see if they will plug into the unit. If not take the unit to radio shack and buy one that does.
Apr 29, 2012 | Cobra Micro Talk Pr3000dx Two Ways Radios...
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
Need power cords and phone chargers
They are available on eBay for quite cheap, I just did a quick search and they can be had for under $10 including shipping. Depends on the exact model number of your unit, there wasn't a huge selection.
Jan 08, 2009 | Durabrand PDV-709
Gateway T-1625 Laptop won't boot up at all
It sounds like a motherboard issue. The fan spinning and the LED lights are running off of battery power. This indicates that power is getting to the system. You should look into replacing the motherboard at this point. Before you replace the motherboard feel your system to see if there are any really hot spots that would indicate overheating. If not proceed with the replacement. If so, let me know where the hot spot is.
Dec 20, 2008 | Gateway T-1625 Notebook
Lands Phones Logo
47 people viewed this question
Top LG Lands Phones Experts
Are you a LG Lands Phone Expert? Answer questions, earn points and help others
