Does my tv need to be hooked up to cable to run setup? if so, can i run hdm1 cord from my other tv to this one to retreive signal?
  • 2794 Answers
SOURCE: sanyo dvw 5000 setup
If you rabit ears have a ribbon cable you will need a coax adaptor. Radio Shack carries them. If you cant find them, you might have to get a set of rabit ears that has coax wires. The antenna will plug into the cable in of the DVR. You take the coax output and plug that into the tv using a coax wire.
Posted on Aug 04, 2008
  • 98 Answers
SOURCE: on HDM1 "No Signal" cannot get anything!
check the cable once more then nothing different?
replace the Main Board
Posted on Feb 06, 2009
  • 362 Answers
SOURCE: Swtiching to Digital tv
If you are connected to Cable TV service you are probably already setup, but here are a few things to check for.
  1. From the Menu, make sure the tuning band is set to Cable and not to Air or Antenna.
  2. From the Menu perform an Auto Channel Search.
That should be all you need to do.
Now if you want the best High Definition picture, believe it or not you will need an Antenna, depending on your location you will be able to pick up OTA (over the air) channels in the purest form.
I can help you with this also, let me know. Lone99star Please rate this solution.
Posted on Feb 17, 2009
  • 59 Answers
SOURCE: my tv only has a cable hook up how do i hook a dvd player with red white and yellow cords
put the tv on av
#yellow cord in yellow socket
#red cord in red socket
#white cord in withe socket
now power the dvd
#Yellow cord in yellow socket
there will be 2 places for the red and white cords
#the red and white cords must be inserted in the audio,
# you will see them next 2 each other
insert them you it will work.
For More Info Email To
Posted on May 11, 2009
  • 105 Answers
SOURCE: hook up to my Samsung 42" plasma TV
Hi There what you need to do is to enable your external vga port this is normally done by pressing your fn ky along with one of the f keys the f key normally has a oblong with a square inside it f4 or f7 seem quite common
If You find this of use please dont forget to leave feedback
Regards AL " Alstech"
Posted on May 25, 2009
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
How should hdm1 cord go between tv and DVD player
If the dvd player has an hdmi output, insert 1 end of the cable there and the other end of the cable insert it behind the tv into the hdmi input. Just make sure that both dvd and tv have hdmi to hook up both together .
Oct 16, 2014 | Sony Televison & Video
When I hook my tv up to cable I get no signal, if I just hook it up with antenna it works fine. How do I get my tv to work with my cable cord? Would be nice to view cable channels instead of just 3...
It sounds like you are hooking the cable to the wrong input (digital instead of analog) or you do not have an analog input. If you do not have an analog input you could run the cable through a VCR to convert the signal to a separate audio/video signal and send it to the TV via an auxillary input. Without the model number I can't give you much more help.
Thanks for using FixYa and for the great rating.
May 09, 2011 | Televison & Video
How to Chanel Scan
Tv is hook up to cable tv or free DTV air broadcasting?Have a good antenna source hook up or cable or satellite signals.Go into the tv menu go to SETUP.Go down to CH. press enter pick Cable or Air.Enter for scanning,after it done scanning will get all free DTV air or cable broadcasting channels stations signals.
Feb 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
We recently purchased a sony bravia 55 inch tv. we have a hdm1 cord and have hd channels through Telus optik. i am not certain we have it hooked up for the best picture? can you please instruct us on what...
If you are using the HDMI input, you are using the best hook up that is available.
Is there a particular problem with the picture that does not look good?
Nov 24, 2010 | Sony Televison & Video
Someone gave me a 1998 Daewoo 14N2FC TV recently (with an antenna) but so far I do not know how to set it up. All it is showing is white noise when I select setup and go through all the channels with the...
you will either need a converter box (which hooks up with a normal coax cable in the rear of the tv) or cable/satalite tv hooked up to it in order to get a signal
Aug 20, 2010 | Daewoo DTQ-14N2FC 13" TV
Ps3 is not veiwing on my tv
yeah when you change the setting it will give you a few seconds to ok it but if you dont it reverts back to the hdmi btw the composite ones must be attached so go to cousins house hook up hdmi then switch hook up avi cables then ok go home should work fine
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
No signal
This problem requires you to test both the monitor and the signal input form you cable tv setup. Set the monitor up on a computer and see if it works properly. If it does then you may have a problem with the signal conversion of the cable tv to the monitor. It also could be a weak signal that drops below the monitors sensitivity levels. Have your cable tv repairman check the signal levels on your lines. Another way to test this is to hook up is with a different monitor to test your setup and see if it works. If after testing you find, the monitor does not work properly, then you need to have it serviced. Hope This Helps.
Mar 12, 2009 | Envision 19" Widescreen Flat Panel LCD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
