What is preferred userID ?? - Computers & Internet
Cant log on to the wireless motorola 192.168.0.1
If you got to the router's interface by typing 192.168.0.1 and it requested the userid and password. If the password you enter did not let you in, then the password is wrong. Maybe someone changed the default userid and password to something else.
You can always press the reset button on the router to set it back to Factory Settings. Then the default userid and password will work, but you will have to set the wireless back up and configure the basic settings (if you have a userid and password that the phone company uses as the network userid and password. This is not your email address userid and password).
Jun 07, 2012 | Arris SURFboard SBG900 Wireless Router...
How to set up a wireless connection for my mac
I'm taking that you have an airport installed on your mac. Go to system preferences under the apple menu and then go Network click on the "+" sign and then select under interface airport and then under Network Name select you wireless network and you will be asked to insert your userID and password and then click on okay.
Feb 04, 2012 | Apple Computers & Internet
How to turn on wifi for apple computer
I'm taking that you have an airport installed on your macbook. Go to system preferences under the apple menu and then go Network click on the "+" sign and then select under interface airport and then under Network Name select you wireless network and you will be asked to insert your userID and password and then click on okay.
Feb 02, 2012 | Apple Computers & Internet
I have problem logging into 192.168.0.1 reset my wireless Di-624 router
The default userID and password for the DI-624 can be one of 3:
1st userID: admin password: (none) leave it blank
2nd userID: User password: (none) leave it blank
3rd userID: admin password: admin
Jan 26, 2011 | Computers & Internet
I for got my jkc userid password
how to change the userid in jkc actually my btech rollno is different and my jkc userid is different how to change dat
Oct 14, 2010 | Computers & Internet
My laptop ask me primary or administrator password what shall i do to opperate my laptop?
Your laptop is password protected: in order to use it, you need to know a valid userid and passord.
- Primary password: your assigned userid and password (which could just be blank - press enter after entering userid)
- Administration password: enter admistrator userid (such as as administrator or Admin) and the assisgned password (whih could be admin) - Admistrator can override a user locked laptop.
Turning the power off to the laptop will reset the laptop to 'normal' usage but may still require a userid and password.
Hope it helps.
Sep 28, 2010 | Dell Computers & Internet
What is the difference between my email userid and yahoo im
If you have a yahoo userid and a password, it means that you own a yahoo account, as well as an instant messenger account. In other words, same yahoo userid and password can be used for email as well as instant messenger. If you use the same userid for email and instant messenger, then the password should also be the same, which belongs to the userid which you use. If you want to use different user id and password for email and instant messenger, you can create two userid's and use one for email and the other for the instant messenger.
Sep 09, 2009 | Yahoo Messenger
Access authorization code
I think this is the one you want to change. If not let me know please.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [System Administrator Settings]. The System Administrator Settings screen will be displayed.
  7. Select [System Administrator Login ID]. The System Administrator Login ID screen will be displayed.
  8. Select [On].
  9. Enter a new System Administrator userID in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  10. Select [Next] and re-enter the System Administrator userID in the field provided.
  11. Select [Save] to save the changes.
  12. Select [System Administrator Password]. The System Administrator Password screen will be displayed.
  13. Enter a new System Administrator password in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  14. Select [Next] and re-enter the System Administrator password in the field provided.
  15. Select [Save] to save the password.
  16. Select [Close] three times.
  17. Select [Exit].
    NOTE: Make note of the new System Administrator userID and password. If the new System Administrator userID and password are forgotten, a service call must be placed
Jan 29, 2009 | Xerox CopyCentre C123 Copier
I need to change the access code as some non authorized people are using my photocopier. How can I do that?
I am answering this twice since it appeared twice, If this isnt the code you want to change let me know. I believe this is the one you are asking.
  8. Select [On].
  17. Select [Exit].
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
