How do I set for series recording - Televison & Video
Have two in seperate rooms and neither will now record whole sries!!!
If you have added padding to the start and/or end of the recordings, this will disable series record.
In the Record Menu, set Start and End times to On Time if you want to use Series Record.
Nov 02, 2015 | Humax PVR9300T HD DVR
Recording series (mad Men). Recording all but only saves 7. Can I increase # saved?
What is the make and model?
On some DVRs, you can go to Series Manager and look at Options. Under Options, there is a setting for maximum number of episodes to keep.
May 16, 2015 | Computers & Internet
Series record facility has disappeared from my Humax PVR9150
If you have added 'padding' to the start and end of recordings, this will disable Series Link on this model.
In the Record menu, Reset start and end times to 'On Time'.
Apr 12, 2015 | Humax Televison & Video
Why I can't get my machine to record more than one programme, i.e. it will not record a series of programmes?
In the Recording menu of the Humax PVR-9300T (or (9200T), if the start or end times are set to anything other than "On Time", series recording is disabled.
Jan 07, 2015 | Televison & Video
Why is it not recording when on standby
To select a programme to record, press the OK button, it will then give you options such as HD or SD, One-off or Series.
Aug 28, 2014 | Televison & Video
We have set a message on our 5401 phone by pressing *8401 to set. Does anyone know how to remove the message we cannot!
Just record something else over it. Record dead air.
Or remove the lines from going there.
Aug 24, 2010 | Avaya 5400 Series 5410 Phone
Grundig GUFSDTR500HD FreeSat PVR Problem
Hi There, I've never had this problem with my Sky box, it knows which programs are repeats. I suspect its a problem with the GUFSDTR500HD. I have had two of these boxes from Costco, and both have both been as buggy as hell. They have recorded random programmes, they have missed recording programs, they often crash (black screen), series link seems to get it's knickers in a twist, and the up and down directional buttons fail to work after coming out of the guide or menu screen. To top it off, I found that the remote control also interferres with my B&Q fireplace... cycling through the colours when I change channel. Both of these boxes have gone back to Costco and I will never touch another Harvard Group (previously Alba, including Bush/Goodmans/Grundig) box again. Back to sky HD for me!
Feb 24, 2010 | Televison & Video
Art Tube MP Project Series preamp how to set up comp to record
USB option does not work at all q as they said....Their use manual only makes marketing...It is not nice.
if I ask simple step by step. What is problem with it?
I fed up to use USB option ( no rec signal ) on this unit cause I have been told, better to use Yamaha mix device....
best.
V.
Sep 29, 2009 | Dual ART DPS II Preamp System with Tube...
I can't find a Humax/Tivo repair service san francisco peninsula
Try tivorepair@gmail.com. Services SF Bay Area (Peninsula, San Jose, East Bay). They make housecalls. Can repair and upgrade all Tivo's - Series 1, Series 2, Series 3 (including your Humax)
Apr 16, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
All of a sudden our DVR won't record a show that is set for a season series. We have to set everything for one time only record.This just started this week. We don't know what to do.
what you will need to do to correct this problem is delete the series recording. in your list (push list button) highlight the program you wish to delete, push select go to "rec. series" press select. and delete ALL push select... get "ok" message, select again. and reset receiver on front panel of receiver there is a door you can open, hit the red reset button and then setup your series record again by going into the guide and pressing record twice. this will fix the problem by deleting ALL of the series record and resetting, and resetting up series record
Mar 26, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
